1 Pages (10 items)
Fractal Tree - a programme for displaying a fractal tree - Messages
#1 Posted: 3/15/2020 2:48:37 PM
I have created a programme to display a fractal tree in a 2D plot.
fractal tree.sm (7.93 KiB) downloaded 1404 time(s).
fractal tree.pdf (209.83 KiB) downloaded 866 time(s).
I would be interested to find out if there is a way to animate the plot process so that the fractal tree is drawn element by element, as each point is calculated.
Can anyone give me any pointers on how to do it?
If that is not possible, how would the animation be done after all the plot points are calculated?
Thank you
Gerard Bush
Thank you
Gerard Bush
Davide Carpi 3/16/2020 12:19:00 PM
#2 Posted: 3/15/2020 6:30:25 PM
WroteI would be interested to find out if there is a way to animate the plot process so that the fractal tree is drawn element by element, as each point is calculated.
Like this ... in ½ points.
fractal tree.sm (11.31 KiB) downloaded 1394 time(s).
#3 Posted: 3/16/2020 7:13:02 AM
... hard to size the animation plot canvas.
Otherwise renders well ½ length ... greedy 1533 frames !
Search "Samples"... "Pattern" for lot more.
If you can't find and want more: please ask for.
Pattern fractal tree.sm (17.6 KiB) downloaded 1328 time(s).
#4 Posted: 3/16/2020 8:16:56 AM
Thank you Jean,
That is just what I was looking for.
To reduce the number of points, and reduce the calculation time the minimum length can be increased. For example, change 'if lenght > 0.25' in the tree function to 'if length > 1.0'. I guess this could even be defined as a variable.
Cheers,
Gerard
Pattern fractal tree.sm (18.39 KiB) downloaded 1328 time(s).
Cheers,
Gerard
#5 Posted: 3/16/2020 9:04:22 AM
In the program Jean I added the growth of the tree
Pattern fractal 1.sm (12.54 KiB) downloaded 1339 time(s).
5 users liked this post
Davide Carpi 3/16/2020 12:19:00 PM, Alvaro 3/17/2020 4:15:00 PM, Вячеслав Мезенцев 3/16/2020 1:59:00 PM, frapuano 3/16/2020 9:35:00 AM, Gerard Bush 3/16/2020 10:55:00 AM
#6 Posted: 3/16/2020 5:55:35 PM
WroteThat is just what I was looking for.
Few more attached ... Search Julia, Mandelbrot in Forum.
Pattern Koch.sm (11.2 KiB) downloaded 1345 time(s).
Pattern Frieze Heppi.sm (11.97 KiB) downloaded 1368 time(s).
Pattern Hilbert.sm (8.53 KiB) downloaded 1320 time(s).
Pattern Patch Work.sm (10.92 KiB) downloaded 1358 time(s).
Pattern Fractal Sierpinski.sm (10.92 KiB) downloaded 1383 time(s).
Pattern Snail.sm (26.85 KiB) downloaded 1367 time(s).
Pattern Fern.sm (19.4 KiB) downloaded 1380 time(s).
Pattern Sierpinski Kover.sm (16.72 KiB) downloaded 1361 time(s).
Pattern Etoile Magic [Short].sm (46.69 KiB) downloaded 1151 time(s).
Pattern Sierpinski Triangles.sm (35.21 KiB) downloaded 1337 time(s).
Pattern Prototile.sm (116.5 KiB) downloaded 1418 time(s).
#7 Posted: 3/16/2020 5:59:14 PM
Pattern PythagorasTree.sm (6.99 KiB) downloaded 1385 time(s).
#8 Posted: 3/17/2020 3:24:27 PM
Hello Gerard ! ... today, I have cut the tree for You.
Pattern fractal tree [CUT].sm (11.03 KiB) downloaded 1137 time(s).
Gerard Bush 3/18/2020 9:56:00 AM
#9 Posted: 3/18/2020 9:58:54 AM
Thank you very much, Jean and Ber7 for your additions!
#10 Posted: 3/18/2020 12:06:31 PM
3 users liked this post
Davide Carpi 3/18/2020 3:07:00 PM, Gerard Bush 3/18/2020 4:59:00 PM, NDTM Amarasekera 3/19/2020 6:03:00 AM
1 Pages (10 items)
