Insert Values Into Existing Matrix
Insert Values Into Existing Matrix - How to insert values into a matrix as opposed to replacing - Messages
#1 Posted: 12/31/2019 2:10:16 PM
Ryan Freund
Ryan Freund
20 likes in 339 posts.
Is there an easy way or built in way to insert values into a matrix?
For example if I have a 2x4 matrix and I want to insert a column. How can this be done?
Is it possible to sort a matrix so that the columns are rearranged until the specified row is in ascending order?
If not is there a way to invert a 2x4 matrix so that the row is now the column. See attached example.
Thanks
Matrix Manipulations.sm (6.61 KiB) downloaded 1135 time(s).
#2 Posted: 12/31/2019 5:08:03 PM
1. Insert col(s)/row(s) from somewhere in the attached
2. Transpose/csort/re-transpose.
Utilities Matrix Treasury_1.sm (408.9 KiB) downloaded 1216 time(s).
#3 Posted: 1/4/2020 11:03:47 AM
Ryan Freund
Ryan Freund
Thank you Jean!
