Can smath code base be recompiled under .NET 3.0?
Can smath code base be recompiled under .NET 3.0? - More extensions become possible if smath moves to .NET 3.0 - Messages
#1 Posted: 9/17/2014 10:14:32 AM
gnc
gnc
0 likes in 2 posts.
There are several open source options for nice 3D graphics extensions, but they use .NET 3.0. I'm particularly interested in www.dislin.com, free despite the .com
.NET 3 is backwards compatible w/ 2 so this move would not break anything and everyone should have .NET unless they are still running XP which is no longer supported.
#2 Posted: 9/17/2014 10:19:00 AM
1,436 likes in 2,918 posts.
Actually you can make plugins using any .NET Framework up to the 3.5 (f.e. the XlsxImportExport plugin is targeted to that framework)
#3 Posted: 9/17/2014 2:27:17 PM
gnc
gnc
0 likes in 2 posts.
Excellent news, thank you. (Documents still say .NET 2)
#4 Posted: 9/17/2014 5:24:37 PM
.NET 2 is the basic requirement to run SMath; this means that you can run it just if you have the .NET Framework 2/3/3.5 installed in your system, and doesn't work if you have previous versions installed (1/1.1). Frameworks 2/3/3.5 are all based on the same CLR, so you can develop plugins targeted to any of these versions.
references: .NET Framework Versions and Dependencies
