HVAC Constants (IP)
HVAC Constants (IP) - Derive HVAC Constants in SMath - Messages
#1 Posted: 1/8/2021 10:24:21 PM
Ruben Sidranski
Ruben Sidranski
17 likes in 465 posts.
Good evening,
Looking for suggestions to better improve the maths. I am working on the write up on the side on another Sheet.
I'm having an issue in when it comes to eliminating units, better yet, proving units cancel out. Suggestions on how to better derive and show the process is appreciated.
HVAC Constants.sm (55.22 KiB) downloaded 1152 time(s).
Alvaro 1/9/2021 5:15:00 AM
#2 Posted: 1/9/2021 5:18:20 AM
1,138 likes in 1,805 posts.
Good evening,
Hi. SMath convert all numbers to it rational approximation in symbolic outputs. Maybe you can use this trick: put Q*ΔT in units and use numeric evaluation:
#3 Posted: 2/10/2021 1:22:13 PM
Ruben Sidranski
Ruben Sidranski
Help with the highlighted please. How do I put the variables into Units? File is updated on my laptop to numeric evaluation.
#4 Posted: 2/10/2021 2:20:26 PM
The error message reads yellow not defined
#5 Posted: 2/10/2021 3:00:17 PM
Ruben Sidranski
Ruben Sidranski
And ALVARO had a way around it where his SNIPPET/PICTURE shows what I want
#6 Posted: 2/10/2021 3:08:42 PM
HVAC Constants.sm (62.47 KiB) downloaded 1179 time(s).
Hi. Just write them: " Q*ΔT*'BTU/'hr " in the unit's placeholder.
I attach the file too.
sergio 2/10/2021 3:39:00 PM, ElSid 2/10/2021 3:45:00 PM
#7 Posted: 2/10/2021 3:46:22 PM
Ruben Sidranski
Ruben Sidranski
Got it. You force the solution (=) side to keep Q and ΔT as variables. I think I tried everything BUT that!
Revised file HVAC Constants.sm (62.98 KiB) downloaded 1129 time(s).
