Mathcad While / Smath For
Mathcad While / Smath For - Help with the structure - Messages
#1 Posted: 9/7/2021 5:07:55 PM
metrvg
metrvg
0 likes in 5 posts.
Hello guys, please your help! I've trying for weeks to do the equivalent WHILE in Smath Studio... a big tool for me. But I really cant figure it out, after watching thousands of videos and web pages. This might be a dumb question, but I'm kinda desperate.
I keep getting Z is not defined.
See the following captures:
Mathcad
Smath Studio
Thank you very much in advance.
#2 Posted: 9/7/2021 5:36:04 PM
599 likes in 1,380 posts.
SMath vectors/matrices don't start with 0 index.
First matrix/vector element gets the index 1.
Redesigning your code should make it tick.
Either make your indexes +1 or change your range to start with 1.
metrvg 9/14/2021 5:06:00 PM
#3 Posted: 9/8/2021 11:33:22 AM
The mountains of Mathcad that I converted for Smath were done simply.
1. From the Mathcad default index 0, save the result.
2. set Mathcad ORIGIN 1
3. Run the program, doctor as indicated by the red message.
I still have a gorgeous Mathcad ORIGIN 0 that couldn't be
converted/doctored ORIGIN 1 ... Damned mystic to me !
Cheers ... Jean.
#4 Posted: 9/8/2021 4:35:53 PM
Does it make sense to sanity Smath vs Mathcad more generally ?
Page9 Sanity Mathcad.sm (8.19 KiB) downloaded 1399 time(s).
#5 Posted: 9/10/2021 2:12:09 AM
wty3000
wty3000
0 likes in 5 posts.
when I download the attachment, run it,
the error happens : "j is not defined"
Is it my PC's problem?
#6 Posted: 9/10/2021 7:12:50 PM
PC problem ? Maybe as no visitor reported problem.
#7 Posted: 9/11/2021 10:44:48 AM
Could you please uninstall SMath and delete your smath config directory.
Directory should be in "C:\Users\\AppData\Roaming\SMath\".
Delete the SMath directory in Roaming completely, purge it.
And could you please download new version again and install it?
#8 Posted: 9/12/2021 11:35:40 AM
You can probably doctor wrt your SS version.
Cheers ... Jean.
#9 Posted: 9/14/2021 5:05:39 PM
metrvg
metrvg
0 likes in 5 posts.
Guys, thanks for your advices, i've been progressing with Smath... BUT, I reached a new issue... and I still don't get it...
i even did the calls step by step marked in red.
What can be wrong in the sintax??
Check this out:
Mathcad
Smath
Thank you very much in advance!
#10 Posted: 9/14/2021 5:25:05 PM
What can be wrong in the syntax??
We can't really tell what is the matter without the file.
I guess you tried to see the result in same region with the algorithm.
Same region result evaluation won't work with multi-line calculations.
But it will give you the correct results in a separate evaluation.
The syntax seems to appear correct. There is no problem with syntax.
When I wrote everything as you did, it just works.
Here is your algorithm written from scratch.
syntax.sm (5.16 KiB) downloaded 1243 time(s).
metrvg 9/14/2021 7:37:00 PM
