How to change the equation font to match text font
How to change the equation font to match text font - Changing the equation font - Messages
#1 Posted: 3/12/2022 6:56:33 PM
lyle mariam
lyle mariam
0 likes in 3 posts.
When I print a worksheet the equation portion is lighter in color and weight than the text regions. I see how to increase the font size of the equation but is it possible to change the font of the equation portion? I'd like the equations to be nice and dark like the text region is. The font selection for the equations doesn't seem to be selectable?
#2 Posted: 4/7/2022 10:49:43 AM
⚜ Kenny Lemens, P.E. ᵂᴵ
85 likes in 181 posts.
Greetings,
I would refer you to the following Topic: https://en.smath.com/forum/yaf_postst17669_Possible-bug-printing.aspx
Hello!
Thank you Andrey for reading this topic. It's the first time I can say THANK YOU for SMath Studio. I hope to further collaborate with this wonderful project, I am at the very beggining of this trip, since I heard about SMath Studio on april, 2020.
Regarding comments, I would be grateful if we can have a simpler way of changing description and math default font types in a worksheet.
As a workaround that could help you, Melo15, I attach here an image that could be useful. Saludos!
Hope it helps!
test comment.sm (14.58 KiB) downloaded 1541 time(s).
I would advise you to make a copy of the "file:\\C:\Program Files (x86)\SMath Studio\representation\settings.prop" before modifying it, just in case you need to recover it. I did a quick check and it appears to work; however do not be supprised when you see some items (e.g. square root, division symbol) stay with the 'light weight' appareance; these elements are not font based, they are generated to match Courier New Font (Default).
Also, be aware that this modifies how SMath works on your computer and applies to all worksheets; not limited to a specific worksheet as this data is not saved within the *.sm file itself. If you are sharing your documents with other users, you will need them to modify the settings.prop file for effect. If you typically download examples from this forum, you will need to revert the settings.prop back to the original for best effect.
Kenny Lemens, P.E.
