solving an equation with rational exponents
solving an equation with rational exponents - Messages
#1 Posted: 10/31/2012 12:45:04 PM
loitzl9006
loitzl9006
0 likes in 4 posts.
I solved this equation:
http://www.fotosik.pl/pokaz_obrazek/25a04e7a09ca7cc1.html using WolframAlpha (y is approximately equal 1,69)
and then I tried to solve the same equation using last version of SmathStudio (0.95.4594) by means of function "solve"
I know that function "solve" acts only in real numbers (in addition, I have arranged a maximum range of roots in Smath (from -1000 to +1000)) and I get a message "no real roots"... Why?
#2 Posted: 11/19/2012 4:10:45 AM
[...] I tried to solve the same equation using last version of SmathStudio (0.95.4594) by means of function "solve"
Hi loitzl9006,
functions solve(2) and solve(4) works for me, both with standard or custom range (see the attachments)
there may be an error in your function?
regards,
w3b5urf3r
eq.sm (4.23 KiB) downloaded 1350 time(s).
#3 Posted: 11/22/2012 8:12:16 AM
loitzl9006
loitzl9006
0 likes in 4 posts.
I change option "Answer (set)" into "Auto" and now my problem is solved! thank you!
