"Cannot find file" error on saving
"Cannot find file" error on saving - "Cannot find file" error on saving - Messages
#1 Posted: 8/25/2022 10:52:31 AM
Peter J Francis
Peter J Francis
0 likes in 18 posts.
I'm getting the following error when saving a sheet
i'm using Version 1.0 (build 8151)
I've tried disabling various extensions but its still happening
Any help will be much appreciated
Peter J Francis Twitter: @PeterJFrancis Thermal Engineer , Maker , Pilot
#2 Posted: 8/25/2022 10:57:34 AM
Try disable AV's [Anti Virus] before saving.
Peter J Francis 8/25/2022 11:48:00 AM
#3 Posted: 8/25/2022 11:03:31 AM
Peter J Francis
Peter J Francis
Hi Jean
Thanks for the reply , I tried that .... still get the error
I've also tried it on 2 different PCs with no luck
#4 Posted: 8/25/2022 11:35:53 AM
Hi Jean
From recollection, I think Davide could recuperate.
Wait and expect SS Community will help.
#5 Posted: 8/25/2022 5:51:27 PM
597 likes in 1,377 posts.
- Update SMath to latest stable (1.0.8253),
- Update all installed plugins to latest versions,
- Try to run SMath as administrator.
Peter J Francis 8/30/2022 4:06:00 AM
#6 Posted: 8/25/2022 7:02:14 PM
1,442 likes in 2,934 posts.
The error message seems related to something in the ImageEditRegion plugin
<ProjectGuid>{63DDAEF8-9A56-4FF6-938E-D590B638BF99}</ProjectGuid>
#7 Posted: 8/30/2022 4:16:02 AM
Peter J Francis
Peter J Francis
Thanks Davide,
I just disabled ImageRegion plugin and the error disappeared when i saved the sheet
Overlord - thanks for your answer
I can't upgrade to the latest stable yet as the client is using the same version as I am
thank you all for your help
Peter
