1 Pages (4 items)
Lagrange Multipliers - Lagrange Multipliers - Messages
#1 Posted: 10/22/2018 4:52:10 PM
Draghilev is on the menu ... is it applicable in there ?
Maths Lagrange Multipliers Copy.sm (59.81 KiB) downloaded 1300 time(s).
#2 Posted: 10/23/2018 8:05:41 AM
WroteDraghilev is on the menu ... is it applicable in there ?
Hi Jean. Yes, it is ... but just give only one point, because there are only one solution. And the method requires at least one starting point ...
Drag_Jean.pdf (54.46 KiB) downloaded 829 time(s).
Drag_Jean.sm (49 KiB) downloaded 1344 time(s).
#3 Posted: 10/23/2018 6:06:21 PM
Maximization added.
Drag_Jean max and min.pdf (76.37 KiB) downloaded 830 time(s).
Drag_Jean max and min.sm (56.51 KiB) downloaded 1244 time(s).
#4 Posted: 10/23/2018 11:18:35 PM
WroteMaximization added.
Thanks Alvaro ... gorgeous solutions.
The Draghilev part persists "Syntax incorrect".
Don't worry Alvaro: You are doing so much for Smath Community !!!
Maths Lagrange Multipliers Alvaro [Maximize-Minimze] Copy.sm (23.64 KiB) downloaded 1186 time(s).
1 Pages (4 items)
