Maxima Plot path error
Maxima Plot path error - Messages
#1 Posted: 3/21/2019 2:41:14 PM
Topsi
Topsi
0 likes in 8 posts.
Hello SMath user,
Plotting with Maxia doesn't work. Insert /Maxima/ 2D-3D plot
results in an error message..: Cannot find the path (see appendix).
In the German language the character o with arc does not exist.
Here the path name contains the a with points ä . Can I use the
Set path Are there other possibilities? Want to use Maxima plot
not with 3DPlot.
Thank you
topsi
#2 Posted: 3/21/2019 6:08:11 PM
1,355 likes in 2,271 posts.
Normally the plugin should be unicode-proof. It uses SBCL. Does the plot work in wxmaxima?
