Unit Conversion
Unit Conversion - Change from International System Units to other derived units - Messages
#1 Posted: 4/24/2022 12:34:20 AM
CBG
CBG
78 likes in 312 posts.
Hello
Does anyone know how to change the following units in the matrix shown below?:
from "kg/s" to "t/hr",
from " kg/{'m*'s^2}" to meters Water Column ("mH2O"),
"{'kg*'m^2}/{'s^3}" to Watts.("W")
Colebrook_SI_CBG.sm (29.41 KiB) downloaded 1261 time(s).
#2 Posted: 4/24/2022 12:58:52 AM
599 likes in 1,380 posts.
Hello
Possibly not with your original result matrix, if you shall use results later.
It can be shown in a table region or another pseudo result matrix.
Here is the table method.
Click to enlarge
#3 Posted: 4/24/2022 1:46:38 AM
Here is your matrix with pseudo units.
Not very elegant, but it is there.
Clickto enlarge
#4 Posted: 4/24/2022 3:05:54 AM
1,138 likes in 1,805 posts.
Hola Carlos. You can use matrix algebra in the unit placeholder. Here one solution.
Colebrook_SI_CBG.sm (24.74 KiB) downloaded 1286 time(s).
#5 Posted: 4/24/2022 11:21:48 AM
from " kg/{'m*'s^2}" to meters Water Column ("mH2O",
Hola, Carlos
Moody as stand alone.
#6 Posted: 4/24/2022 12:59:14 PM
Hola, Carlos
Relation with what Carlos asked?
None, as usual.
#7 Posted: 4/24/2022 5:39:01 PM
CBG
CBG
Hello
Many thanks to Overlord for his suggestions and solution.
Muchas Gracias tambien a Alvaro por su solucion.
I also thank Jean.
#8 Posted: 4/24/2022 5:53:16 PM
None, as usual.
Project is Colebrook, of which the core algo is Moody.
Read Alvaro to learn more.
#9 Posted: 4/24/2022 6:08:40 PM
Reading you in mathcad forums is also instructive.
https://www.eng-tips.com/viewthread.cfm?qid=335795
#10 Posted: 5/2/2022 1:24:12 PM
Ruben Sidranski
Ruben Sidranski
17 likes in 465 posts.
WOW, I feel old. I didn't even remember I was on that forum/website. Thanks for the memory...
#11 Posted: 5/22/2022 9:36:36 AM
Stevan
Stevan
0 likes in 3 posts.
How do I set my units so my answers are in the unit I want, at the moment the answer is being returned to Pa (Pascal) and I would prefer to have the answer in kPa(KiloPascal) or even kN/m^2.
I am also getting answers in N(Newtons) and would prefer to have them set to kN (Kilo Newton) rather.
#12 Posted: 5/23/2022 2:17:43 PM
Stevan
Stevan
0 likes in 3 posts.
That moment you realize you didn't save a copy of the problem :/ just redid it and realized I have a lot to learn about this program
Thanks for the welcome
Coversion Problem.sm (26.14 KiB) downloaded 1277 time(s).
#13 Posted: 5/23/2022 6:32:27 PM
How do I set my units so my answers are in the unit I want?
Your attached document is fine. Jean's computer is broken.
About your question, there is a placeholder within results.
It will appear when you select result. It appears as a black square.
You can change your desired result units by altering it.
Here is a demonstration how you can do that.
#14 Posted: 5/23/2022 8:53:08 PM
Stevan
Stevan
0 likes in 3 posts.
I had a feeling it was going to be something so simple, this is brilliant, thanks!
