SMath Studio 0.97.5154 (10 Февраля 2014)
SMath Studio 0.97.5154 (10 Февраля 2014) - Messages
#1 Posted: 2/9/2014 8:05:43 PM
2,345 likes in 4,059 posts.
Доступна новая версия SMath Studio 0.97.5154
Последние изменения
  • Extensions Manager implemented;
  • Feature to show result right after definition implemented;
  • Go to definition Context menu item implemented;
  • Added ability to change language translation for SMath Viewer;
  • SMath Viewer fixed to support Area Regions protected by password;
  • Worksheet's properties: Author and Company - is now reflected in output SMath Viewer (*.exe) files meta-data;
  • Fixed calculation issue appears on combination of the following settings: "Answer type" = "Auto" and "Decimal places" > "13";
  • Viewer support for MathRegion improved (for expressions without output values);
  • Fixed issue with plug-ins contain references of external DLLs from "plugins" directory;
  • Multiplication improved for symbolic library;
  • Support for backgrounds images improved;
  • Fixed issue appears if plug-in extends Region's context menu with item(s) contains hotkey binding;
  • Worksheet drawing performance improved;
  • Insert Matrix dialog improved to select input values on focus;
  • MSI installer improved to support different DPI settings;
  • Execution script added to Mono Package;
  • Added ability to export files to supported formats using command prompt;
  • Fixed critical issue appears on context menu open for Region based on RegionHolder with hidden input data;
  • Dependencies handling improved for sm/smz files;
  • Semicolon symbol prohibited to be used as a part of variable/function name;
  • Added ability to edit link text of Text Region if worksheet in edit mode (use Ctrl+Click to open linked document);
  • Fixed issue appears sometimes on Context menu loading for focused or selected Regions;
  • Fixed issue appears on saving document opened by link from another worksheet (initial worksheet was overridden);
  • Fixed issue appeared on plug-ins loading;
  • Fixed invalidation issue on focus regions based on RegionHolder (f.e. Plot Region);
  • Fixed issue when it was impossible to get current file name from plugin;
  • Complexities in sys(), line() and matrix() resizing fixed;
  • Fixed issues of opening Dynamic Assistance list after collapsed Area(s);
  • Handling of broken plug-ins on application loading and on plug-ins installation improved;
  • Backspace handling improved when cursor is on the worksheet;
  • Inserting number before variable automatically sets multiplication operator between those number and variable;
  • Fixed unhandled exception on copy/paste of empty placeholder;
  • German units names added;
  • Added support for text entries and descriptions of not installed language;
  • Code certificate updated;
  • Fixed issue with "RIGHT" string appearing for some locals.
  • Language files updated;
  • Refactoring and optimizations.
Системные требования
  • Desktop (Windows):
    Среда: .NET Framework 2.0
  • Desktop (Linux):
    Среда: Mono 2.0 (libmono-winforms-2.0-cil package) и выше
Поддерживаемые языки интерфейса (37 языка)
  • [ARA] Арабский / Arabic / العربي
  • [BEL] Белорусский / Belarusian / Беларуская
  • [CAT] Каталанский / Catalan / Català
  • [CHS] Китайский Упрощённый / Chinese (Simplified) / 简体中文
  • [CHT] Китайский Традиционный / Chinese (Traditional) / 簡體中文
  • [DAN] Датский / Danish / Dansk
  • [FAS] Персидский / Persian / فارسی
  • [FIN] Финский / Finnish / Suomi
  • [HEB] Иврит / Hebrew / עברית
  • [IND] Индонезийский / Indonesian / Bahasa Indonesia
  • [JPN] Японский / Japanese / 日本語
  • [KOR] Корейский / Korean / 한국어
  • [LAV] Латышский / Latvian / Latviešu
  • [NOR] Норвежский / Norwegian / Norsk
  • [RON] Румынский / Romanian / Română
  • [SCC] Сербский (Латиница) / Serbian (Latin) / Srpski
  • [SLK] Словацкий / Slovak / Slovenčina
  • [SRP] Сербский (Кириллица) / Serbian (Cyrillic) / Српски
  • [SWE] Шведский / Swedish / Svenska
  • [TUR] Турецкий / Turkish / Türkçe
  • [UKR] Украинский / Ukrainian / Українська
    Загрузка
    Справка
    Руководство по использованию SMath Studio (русский язык). Рекомендуется к чтению пользователям, только начинающим работать с программой для выполнения своих расчётов. Спасибо Сергею Аверкину за создание и подготовку документа.
    Справка по программе SMath Studio от Gilberto E. Urroz, Ph.D., P.E. (английский язык):
    Другие файлы
    Иконки программы SMath Studio () всех размеров (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) в формате изображений PNG.
  • 8 users liked this post
    Mikka 2/10/2014 5:02:00 AM, Davide Carpi 2/10/2014 7:12:00 AM, уни 2/10/2014 8:39:00 AM, Даниил 2/10/2014 1:06:00 PM, Serg 2/11/2014 1:40:00 AM, tca 2/11/2014 6:18:00 AM, Rubidy 2/15/2014 7:23:00 AM, Carlos 2/24/2014 8:04:00 AM
    #2 Posted: 3/12/2014 2:39:21 AM
    Serg
    Serg
    7 likes in 105 posts.
    День добрый.
    Так каковы изменения в новой версии?
    Ученье свет!
    #3 Posted: 3/12/2014 4:35:06 PM
    Прошу прощения... совсем забыл про список. Добавил изменения на английском языке.
    К сожалению нет времени сейчас переводить на русский. Может сделаю чуть позже.
    Спасибо, что напомнили!
    Serg 3/13/2014 12:05:00 AM
