1 Pages (18 items)
One more about lens - Messages
#1 Posted: 12/1/2024 1:52:00 AM
How can we use here a Mathcad-block?
Lens-Mathcad-Block.sm (43.8 KiB) downloaded 1796 time(s).
See too
https://en.smath.com/forum/yaf_postst25212_Lens.aspx
See too
#2 Posted: 12/1/2024 6:08:12 PM
WroteHow can we use here a Mathcad-block?
Here the function rkfixed() can't process the incoming expressions correctly. The block has nothing to do with it, it does not perform detailed analysis of expressions.
This is a bug in the function. The function has not been tested for this case. I can't see what's wrong here right now.
Valery Ochkov 12/2/2024 3:44:00 PM
#3 Posted: 12/1/2024 7:52:45 PM
This is not a solution of the rkfixed problem, just a little playing around with X-Y plot.
Here, an option of setting the aspect ratio of the axes to 1 would be good.
#4 Posted: 12/7/2024 1:02:58 PM
#5 Posted: 12/8/2024 1:05:34 AM
I am wondering if there is such a kind of Mathcad Prime odesolve for solving differential equations numerically also for SMath Studio somehow?
#6 Posted: 12/8/2024 1:21:21 AM
WroteI am wondering if there is such a kind of Mathcad Prime odesolve for solving differential equations numerically also for SMath Studio somehow?
Not yet, but will be soon!
Question - why is the answer meters squared, and not just meters?
#7 Posted: 12/8/2024 2:29:44 AM
What's wrong with the existing solvers?
#8 Posted: 12/8/2024 3:54:39 AM
WroteWroteI am wondering if there is such a kind of Mathcad Prime odesolve for solving differential equations numerically also for SMath Studio somehow?
Because odesolve in Mathcad Prime:
1. Do not require to rewrite the differential equation of a higher order into a system of first order odes
2. Determines whether a system is stiff or nonstiff and then is using accordingly the stiff numerical differential eq solver or nonstiff numerical differential eq solver
3. Can solve numerically a system of differential equations (whatever it's a system of first order differential eq or a system of higher order differential eq)
What are these existing numerical solvers of differential eq in SMath? What are the posibilities of SMath to solve numerically differential equations? Exist at least one solver that mimic the Mathcad Prime odesolve (i.e. the 3 points above menționed)?
#9 Posted: 12/8/2024 5:04:39 AM
Hi Cornel. For points 1 and 3, SMath can do what Mathcad can, and just a little more. Please, check the first post in this plugin. Can mathcad solve this odes?
RKA.sm (308.62 KiB) downloaded 2194 time(s).
RKA.pdf (931.16 KiB) downloaded 1668 time(s).
About point 2, one would have to review the documentation for the following plugins to see if they are capable, and to what extent, of doing what you are asking, and choose it for the solver in the SMath's solver block.
● [topic=17088]Intel ODE Solver Library[/topic]
● [topic=1918]DotNumerics[/topic]
● [topic=13809]SADEL[/topic]
● [topic=1970]Matlab C++ Math Library[/topic]
● [topic=17063]OSLO[/topic]
● [topic=17067]lsoda[/topic]
● [topic=1997]GNU Scientific Library (GSL)[/topic]
#10 Posted: 12/8/2024 8:58:47 AM
See too
Hi. dsol can solve it with this setup:
RKA-Lens.sm (179.91 KiB) downloaded 1769 time(s).
I also use the Martin's setup for the plot.
#11 Posted: 12/9/2024 10:44:48 AM
#12 Posted: 12/10/2024 4:11:05 AM
Hi Valery. This is a way.
spherical aberration.sm (15.88 KiB) downloaded 1756 time(s).
#13 Posted: 12/10/2024 12:38:25 PM
#14 Posted: 12/10/2024 9:21:41 PM
Hi. The screen. I also simplify a little the calculations.
spherical aberration.sm (26.41 KiB) downloaded 1905 time(s).
3 users liked this post
francesco rapuano 12/10/2024 11:05:00 PM, NDTM Amarasekera 12/10/2024 11:16:00 PM, Вячеслав Мезенцев 12/10/2024 11:19:00 PM
#15 Posted: 12/10/2024 9:35:39 PM
WroteHi Valery. This is a way.
Very elegant solution
Alvaro 12/11/2024 6:18:00 AM
#16 Posted: 12/11/2024 3:06:13 AM
Root-free version of the spherical lens
spherical aberration_Kr.sm (12.37 KiB) downloaded 1687 time(s).
#17 Posted: 12/11/2024 6:22:06 AM
WroteVery elegant solution
Gracias Oscar! Pero espérate tantito nomás para que veas lo que puede hacer un doc alemán.
Thanks Oscar! But wait a little longer so you can see what a German doctor can do.
Oscar Campo 12/11/2024 12:09:00 PM
1 Pages (18 items)
