Ideas for further plugins
Ideas for further plugins - Ideas and resources about possible plugin improvements - Messages
#61 Posted: 5/22/2023 7:59:06 AM
Add trapeze integrator to rescue the built-in Simpson as it fails.
Unlimited use per document, each independent 'n'.
#62 Posted: 5/23/2023 11:36:49 PM
Mark R Harris
Mark R Harris
4 likes in 90 posts.
The image region plugin works well for SVGs, thank you.
Unfortunately, when 'saved as' a PDF they are rendered out as rasters (not very good ones).
#63 Posted: 2/12/2026 3:55:40 PM
Alex Fernando Guadalupe rojas
0 likes in 1 posts.
It could be interesting to implement a plugin that allows me to mark a variable located anywhere on my sheet and monitor its value while I change another variable elsewhere. For example, when designing, approval values are often at the end, while the main input is at the beginning. Every time I need to see how a change affects the variable of interest, I have to scroll all the way down to check it, which makes the process very tedious.
#64 Posted: 2/12/2026 4:31:07 PM
127 likes in 342 posts.
(#63) Alex,
For now, you can use the trace() command and launch the debug window with F11.
ioan92 2/15/2026 1:08:55 PM, Davide Carpi 2/12/2026 7:01:57 PM
#65 Posted: 2/12/2026 7:01:41 PM
There was also the split-window Mode, once upon a time.
However, another way could be the use of absolute variables (those that have a leading tilde character in the name).
Define ~abs_variable_name:variable_name after your actual calculation, then put the evaluation of ~abs_variable_name wherever is best for you.
Edited 2/12/2026 7:31:59 PM
sergio 2/12/2026 7:50:45 PM
#66 Posted: 2/13/2026 12:35:57 PM
1,360 likes in 2,275 posts.
This is also an option. It avoids absolute variables, which are a nightmare to type with a german keyboard.
Yet it relies on double recalculation after changes in input.
sergio 2/13/2026 5:20:59 PM, Davide Carpi 2/13/2026 6:42:26 PM
#67 Posted: 2/13/2026 10:38:11 PM
599 likes in 1,380 posts.
What I would like some already existing plugins support Linux Mono, not just Windows.
Edited 2/13/2026 10:38:26 PM
usamakhan 10/17/2026 5:03:49 AM
