Is there a way to determine the units of an arbitrary variable
Is there a way to determine the units of an arbitrary variable - Messages
#1 Posted: 3/10/2016 2:16:37 PM
kevnol
kevnol
5 likes in 9 posts.
Is there a way to determine the unit attached to an arbitrary variable? I would like to be able to do this in a user defined function.
I tried the most obvious thing x/abs(x) but this gives a dimensionless answer.
Anybody got any ideas?
example for clarification
if x=100V I would like to create a function Units(X) to return V or 1.V
#2 Posted: 3/10/2016 2:43:30 PM
Hello kevnol,
You can use UoM() from Custom Functions plugin.
kevnol 3/10/2016 6:54:00 PM
#3 Posted: 3/10/2016 3:06:12 PM
#4 Posted: 3/10/2016 5:15:09 PM
kevnol
kevnol
5 likes in 9 posts.
I am not 100% sure what you are doing Jean but I guess you have abandoned the default unit system and instead you are using your own units which are just unique numbers. Interesting idea but think this system will break down once you introduce compound units (unless you can somehow use prime numbers for basic units). Haven't fully thought it through though.
#5 Posted: 3/10/2016 5:23:24 PM
kevnol
kevnol
5 likes in 9 posts.
Davide
When I try to use UoM() in one of my own user defined functions it doesn't seem to work., Any ideas?
I am trying to use UoM to strip the units off a figure
eg StripUnit(x):=x/UoM(x)
x=50V
StripUnit(x)=50V
Or even more simply
Unit(x):=UoM(x)
Unit(50V)=1
Davide Carpi 3/10/2016 7:36:00 PM
#6 Posted: 3/10/2016 6:17:35 PM
Brian Runagle
Brian Runagle
13 likes in 27 posts.
Try this:
stripunit
I'm not sure why this is needed.
Brian
kevnol 3/10/2016 6:54:00 PM, Davide Carpi 3/10/2016 7:36:00 PM
#7 Posted: 3/10/2016 6:40:58 PM
kevnol
kevnol
5 likes in 9 posts.
Brian
How do I create a multi line function like that? This looks very useful.
Ahh .. Found it in the programming reference. Fun to be had.
#8 Posted: 3/10/2016 7:34:38 PM
Strange behavior, I have to investigate it...
BTW in the Extensions Manager, section Snippets, there is a Snippet called "Operations with units"; if you download it, you can insert the snippet in the canvas typing "Units" and then pressing the TAB key. In this snippet there is a version of UoM made with built-in functions (only for scalars).
#9 Posted: 3/10/2016 7:42:23 PM
... or like this:
kevnol 3/10/2016 8:37:00 PM
#10 Posted: 3/10/2016 7:43:28 PM
Ok ok, I was lost in a glass of water...
UoM was designed to act in a generic way both with symbolic and numeric data... when you use it in a inline function, since x is unknown, his unit is 1 (dimensionless - hold the mouse over the definition); if you want to use it in a inline function you have to use Units(x):UoM(eval(x)). In programming functions (when you use line), eval in the argument is not needed, because the evaluation of UoM(x) is made when you call your function.
Obviously if you know the dimensions the best approach is the one suggested in the post above (#9) by Jean.
#11 Posted: 3/11/2016 6:46:52 AM
kevnol
kevnol
5 likes in 9 posts.
Thank you again David, your input has been very helpful.
The background behind my query is that I use complex number calculations a lot for electrical engineering. Smath handles units well for basic complex number calculations but certain key functions do not work with units (Arg(), Re() and Im()) in particular). You can get around this by dividing off the unit but this looks inelegant and needs to be explained every time I show the work to someone. I hope to write my own user defined functions to replace them and having a UoM() function is a nessecary step.
#12 Posted: 3/11/2016 11:36:46 AM
I use lot of complex too. Im(,) Re(,) work well in Smath 5346.
A short example would help to compare.
#13 Posted: 3/11/2016 12:29:41 PM
kevnol
kevnol
5 likes in 9 posts.
Jean here is an example showing what I mean. The functions Re(), Im() and arg() don't work when the operands have units.
By the way you may be interested in the worksheet I did for a simple AC calculation in the complex domain. it is available in the exampls section under "Engineering" and you can see it here: https://smath.com/wiki/GetFile.aspx?File=Examples/ElecEngExample.pdf
#14 Posted: 3/11/2016 5:43:43 PM
There is more than unit problem. I don't use unit
maths are unitless. BUT I append result in "UnitProject".
Years long fight in Mathcad, conclusion from collabs:
"Jean is right". ISO, Engineering ... formulas are given
wrt the unit system. Revisit the "Visual Graphic" example
just reposted this morning.
#15 Posted: 3/11/2016 8:26:42 PM
2,344 likes in 4,057 posts.
FYI: New build will contain UnitsOf(..) function which returns units of specified expression.
The following file created to test its most important use cases:
6 users liked this post
ioan92 3/12/2016 5:58:00 AM, kevnol 3/11/2016 8:34:00 PM, Davide Carpi 3/11/2016 10:09:00 PM, уни 3/12/2016 12:23:00 AM, frapuano 3/12/2016 3:21:00 AM, Radovan Omorjan 3/12/2016 5:47:00 AM
#16 Posted: 3/14/2016 7:47:36 AM
kevnol
kevnol
5 likes in 9 posts.
Excellent Andrey. I look forward to playing with this new build.
