SMath crashes!
SMath crashes! - This is an old file of mine whic produces SMath to crash - Messages
#1 Posted: 5/8/2013 3:35:40 AM
This is an old file of mine which crashes SMath in the recent version as well. The same file was already mentioned some time ago, but it seems it remained problematic (at least for me). Maybe Andrey forgot about it . Could someone else try to just open it please in order to confirm the crash.
Primer43w.sm (33.99 KiB) downloaded 1632 time(s).
#2 Posted: 5/8/2013 4:02:33 AM
1,364 likes in 2,281 posts.
I can confirm the crash. If you disable automatic calculation in the settings, then you can load the file. Seems that the first call to roots() generates the problem.
Radovan Omorjan 5/8/2013 4:18:00 AM
#3 Posted: 5/8/2013 4:03:26 AM
127 likes in 342 posts.
I confirm, it also crashes for me
Win64
#4 Posted: 5/8/2013 4:24:11 AM
I nagged many times about roots(), and I hope that only roots() is the source of the problem. Anyway, this cause of crash should be removed, if possible. Fortunately, there is Davide Carpi (w3b5urf3r_reloaded) and his NonlinearSolvers plugin
#5 Posted: 5/8/2013 5:32:06 AM
kilele
kilele
134 likes in 397 posts.
No crashes for me in smath-mono.
Vista home basic 32-bit sp2
#6 Posted: 5/8/2013 6:05:35 AM
Yes, I experienced the same thing before. Will test it again when I get to my Linux distro.
#7 Posted: 5/9/2013 6:29:56 AM
2,345 likes in 4,059 posts.
Fixed.
3 users liked this post
Radovan Omorjan 5/9/2013 6:44:00 AM, ioan92 5/9/2013 7:25:00 AM, Davide Carpi 5/9/2013 8:49:00 AM
