HIRES Chokes Smath Rkadapt
HIRES Chokes Smath Rkadapt - HIRES Chokes Smath Rkadapt - Messages
#1 Posted: 10/9/2016 2:37:18 AM
The max span is 0..10 Else attempt gives either two types of error.
The setup is correct but the result is a bit short of production.
Designers: that is just a report for your bed time thinking.
Cheers, Jean
ODE Rkadapt HIRES.sm (562.62 KiB) downloaded 1252 time(s).
#2 Posted: 10/9/2016 4:04:00 AM
Hello Jean,
Why don't you use stiff solvers, for example from DotNumerics plugin. They will cope with this equations well (dn_AdamsMoulton, dn_ExplicitRK45, dn_GearsBDF..).
P.S. By the way, uni made many ode solvers in few plugins, and I think SMath is very good regarding ODE solvers
#3 Posted: 10/9/2016 10:45:08 AM
Thanks Radovan,
Here is well done, Jean
ODE HIRES.sm (41.06 KiB) downloaded 1211 time(s).
