Smath Studio is not Starting
Smath Studio is not Starting - Smath will not even Start - Messages
#1 Posted: 2/21/2023 1:39:04 PM
A B AL-Mahmood
A B AL-Mahmood
0 likes in 7 posts.
My Setup=
Windows 7
4Gb RAM
64 Bit
I get the following:
Solver has Stopped Working
Then get 2 Options
Close the Program
Debug the Program
Please Advice What to Do ?
ABA
#2 Posted: 2/21/2023 5:55:28 PM
1,441 likes in 2,932 posts.
It happens on program start? After loading a worksheet?
#3 Posted: 2/22/2023 12:46:33 AM
A B AL-Mahmood
A B AL-Mahmood
0 likes in 7 posts.
It Happens on Program Start.
for me it is a Puzzle ...
Thanks for trying to Help.
ABA
#4 Posted: 2/22/2023 2:53:19 PM
As first step you can choose the "Debug" option and see if it returns a stack trace (list of code functions involved to some degree with the issue). If it happens copy and paste it here.
As second step, with SMath closed, open a explorer window and in the address bar type
%appdata%
then press return.
There should be a "SMath" folder, rename it as something else (f.e. SMath_backup) and try to start the program again.
#5 Posted: 2/22/2023 3:11:02 PM
A B AL-Mahmood
A B AL-Mahmood
0 likes in 7 posts.
Thanks Again
When I choose "Debug" nothing Happens ...?!
ABA
#6 Posted: 2/22/2023 5:12:49 PM
⚜ Kenny Lemens, P.E. ᵂᴵ
85 likes in 179 posts.
Greetings,
Just so we are all on the same page, what scenario are you currently experiencing?
  1. This the first time using SMath (Just downloaded/installed it) and it does not work
  2. I have been using SMath, and today it just stopped working
    1. Were you informed "New Version Available" and you clicked to install?
    2. Did you just install a new plugin?
    3. Did you attempting adding/changing settings in the Program Folders (e.g., Units.xml)?
If possible, please list the SMath Version you are currently using/installed; answers may change depending if you are using the latest stable version, or a beta version, or a version before v1.00
#7 Posted: 2/22/2023 5:45:18 PM
A B AL-Mahmood
A B AL-Mahmood
0 likes in 7 posts.
My case is : This the first time using SMath (Just downloaded/installed it) and it DOES NOT WORK
Which Version ?: This is the File I downloaded recently for Installation
(Can not Run it to get more Details)
Version 1.0.8348 - Stable (released at 11.9.2022)
Kindly note I have used previous versions of Smath and they worked Nicely
Thanks for your Effort .. Warm Regards ... ABA
#8 Posted: 2/23/2023 6:23:22 AM
Ok, it was worth to give it a try.
Have you tried this?
%appdata%
then press return.
#9 Posted: 2/23/2023 7:16:56 AM
A B AL-Mahmood
A B AL-Mahmood
0 likes in 7 posts.
WOW ... It Worked ...WOW
THANK YOU VERY MUCH
Regards .... ABA
#10 Posted: 2/23/2023 8:38:21 AM
Very good, then it was some extension messing up.
Since you are a fresh user you can probably delete safely the old folder (it contains the extensions downloaded for your account and their settings, as well as f.e. the output data of built-in file writing functions)
#11 Posted: 2/23/2023 9:11:13 AM
A B AL-Mahmood
A B AL-Mahmood
0 likes in 7 posts.
Thank You for the Follow-Up, you must be having
a Deep and Clear understanding of the Product.
May I suggest you write a book about Smath.
