1 Pages (10 items)
How to put signs like paranthesis to collect the data in one place - system, sys(...) - Messages
#1 Posted: 6/7/2016 8:44:41 AM
Hi All
I dont know how to do like this link , to gather my data neatly in one paranthesis , I dont know it's name
http://en.smath.info/forum/yaf_postst7446_About-Units.aspx
#2 Posted: 6/7/2016 10:18:50 AM
It's a system... Type sys and then press the TAB key; it is available even as last element in the "Functions" toolbox (right side of the canvas); using the "argument separator" key (that commonly is comma or semicolon, depending on your settings), you can add more lines.
#3 Posted: 6/7/2016 10:27:47 AM
Thank you very much , but I can not add more lines correctly, it seems that separator is not active
#4 Posted: 6/7/2016 10:39:04 AM
I cannot check right now but I've not noticed issues recently. Go to tools > options and check if you are using the right character.
#5 Posted: 6/7/2016 1:16:37 PM
WroteThank you very much , but I can not add more lines correctly, it seems that separator is not active
In a single column vector, you can add place holder(s): type coma on the last
entered value. If you have too many : press Backspace. If you have constructed
an array [matrix], you need some tool to add/remove cols/rows. These tools are
available in the attached "Matrix Treasury".
Cheers, Jean
Utilities Matrix Treasury Copy.sm (285.74 KiB) downloaded 1267 time(s).
This treasury was made in Smath older OFFicial release [April 2014] 5346.
#6 Posted: 6/7/2016 4:48:15 PM
#7 Posted: 6/7/2016 7:27:11 PM
Please notice that you cannot have results individually next to each subexpression in system: the system is one global expression that contains others, and only top-level expression's result may be displayed.
Also notice, that for systems (or matrices as well) of heterogenous elements, you cannot specify units, and even simple units (like Pa) will be displayed as their internal representation of base units of length, time, mass etc.
For homogenous structures, you may specify the common unit in the rightmost unit placeholder, as usual
One more thing: when posting screenshots displaying a question, it's generally a good idea to accompany it with an .sm file, so that others could avoid re-typing everything trying to reproduce.
С уважением,
Михаил Каганский
#8 Posted: 6/7/2016 9:16:26 PM
#9 Posted: 6/8/2016 8:32:46 AM
Thank you so much for your perfect answers
#10 Posted: 6/8/2016 9:45:47 AM
WroteThank you so much for your perfect answers
Welcome ... two typos expe"r"imental, cros"s"
1 Pages (10 items)
