Problem when closing Extensions Manager on Linux
Problem when closing Extensions Manager on Linux - Messages
#1 Posted: 2/28/2014 8:57:45 PM
Balu42
Balu42
0 likes in 5 posts.
I have tried to post this in the SMath Studio 0.97.5154 (10 February 2014) topic but it said something about a moderator needs to approve my post and it never appeared there so I am giving it a try here.
I am running SMath Studio 0.97.5154 and also SMath Studio 0.96.4868 under Red Hat Enterprise Linux 6 using Mono 2.10.6.
When I open the new Extensions Manager panel in SMath Studio 0.97.5154 it opens and works fine. I can double click on Snippets or Examples and the window closes with no problem and the material gets inserted into my page but if I ever attempt to close that panel by clicking on the X in the upper right corner the program crashes. The message displayed in Terminal is the following:
$ mono SMathStudio_Desktop.exe
Stack overflow: IP: 0x5c5b5b, fault addr: (nil)
Stacktrace:
at (wrapper alloc) object.Alloc (intptr) <0xffffffff>
at System.Windows.Forms.Hwnd.ObjectFromHandle (intptr) <0x00047>
at System.Windows.Forms.Control.get_IsHandleCreated () <0x00073>
at System.Windows.Forms.TreeView.get_SelectedNode () <0x0000f>
at (wrapper remoting-invoke-with-check) System.Windows.Forms.TreeView.get_SelectedNode () <0xffffffff>
at .. () <0x0002b>
at .. (object,System.Windows.Forms.FormClosingEventArgs) <0x0003f>
at System.Windows.Forms.Form.OnFormClosing (System.Windows.Forms.FormClosingEventArgs) <0x00069>
at System.Windows.Forms.Form.FireClosingEvents (System.Windows.Forms.CloseReason,bool) <0x00084>
at System.Windows.Forms.Form.RaiseCloseEvents (bool,bool) <0x0007f>
at System.Windows.Forms.Form.set_DialogResult (System.Windows.Forms.DialogResult) <0x00043>
at .. (object,System.Windows.Forms.FormClosingEventArgs) <0x0008b>
From this point on the last 5 rows keep repeating until I kill the process.
Could someone help me figuring out if this is a bug in SMath Studio 0.97.5154 or is a problem with my Mono installation and if it is my Mono, how to fix it?
Thank you,
Balu
