MathcadFileAccess - The following functions are useful for reading various file types into arrays. - Messages
#21 Posted: 3/27/2014 3:30:38 PM
It has occurred to me that the plugin could send the bin data to the clipboard and then the user could make a paste (control-v) by hand into any folder (as the program HTMtied does)
Another alternative could be using DDE as a layer between windows programs, see:
http://jdde.pretty-tools.com/
http://www.thescarms.com/VBasic/ddeml.aspx
ioan92 3/27/2014 4:12:00 PM
#22 Posted: 3/27/2014 7:42:35 PM
have you tried to write to the %TEMP% or %APPDATA% directories ?
ioan92 3/28/2014 4:23:00 AM
#24 Posted: 3/28/2014 6:00:10 AM
Ioan, i'm not sure to understand the problem well
perhaps you can use DAvide's hyperlink plugin
ioan92 3/28/2014 6:22:00 AM
#25 Posted: 3/28/2014 9:25:05 AM
don't ask me why but i think that'll work if you place the sm files at the same directory as smath exe
ioan92 3/28/2014 11:57:00 AM
#26 Posted: 3/28/2014 12:30:28 PM
the two large buttons at the bottom are green in my case, tested with martin's portable version on xp
ioan92 3/28/2014 12:38:00 PM
#27 Posted: 4/24/2014 6:15:34 PM
Updated. Play() function now works as expected (it waits for the end of sound).
Davide Carpi 4/24/2014 7:22:00 PM
#28 Posted: 9/15/2015 2:37:12 PM
This is as good a place as any:
Is there a function that returns the filename of the current worksheet/Smath Document? I couldn't find it
#29 Posted: 6/7/2017 4:12:30 AM
WroteThis is as good a place as any:
Currently I have the same question and also no answer (and couldn't find one).
Can anybody help?
#30 Posted: 6/7/2017 3:20:56 PM
WroteIs there a function that returns the filename of the current worksheet/Smath Document?I couldn't find it
Simple but not so simple, EXPLAIN:
1. If your work sheet resides in a subfolder: don't know if possible [didn't find trick]
2. If your work sheet reside in a folder in "C:\ ==> like this
path:=CurrentDirectory("")
path="C:\Smath6179\"
#31 Posted: 6/7/2017 9:42:05 PM
#32 Posted: 6/8/2017 3:16:49 AM
WroteWroteIs there a function that returns the filename of the current worksheet/Smath Document?I couldn't find it
Hi Jean,
I do know 'CurrentDirectory( "" )' but it returns the path without the filename. And I am trying to retrieve the latter.
#33 Posted: 6/8/2017 8:38:18 AM
WroteI do know 'CurrentDirectory( "" )' but it returns the path without the filename. And I am trying to retrieve the latter.
If I open a work sheet from "My Computer, C, click on the Folder, click on the work sheet
it will open Smath and CWD= is from which folder the work sheet comes from [Snippet].
Differently, If I open Smath first from the task bar, and click on the file name from the
file list on the Smath menu, I get: CWD="C\Program Flies\Smath Studio"
In fact, my Smath is so simple ... all my 925 work sheets are piled in Smath6179 folder.
All in all => same as Mathcad 11
#34 Posted: 6/8/2017 9:05:42 AM
WroteWroteThis is as good a place as any:
Can anybody help?
As workaround you can use simple C# script for this (Script plugin).
store.AddDefinition( terms[0].Text, new Term[0], new Entry( "\"" + store.FileName + "\"" ) );
#35 Posted: 6/8/2017 11:46:34 AM
A more complete code would look like Mathcad 11
CWD="C:\Program Files\Mathsoft\Mathcad 11\Handbooks\datapack"
#36 Posted: 10/29/2019 5:05:48 AM
The function getfolderpath() seems to be broken for build 7219:
getfolder.sm (2.21 KiB) downloaded 1785 time(s).
![2019-10-29 07_52_04-SMath Studio 0.99.7219 - [Blatt5_].png](/en-US/files/Download/spgdML/2019-10-29-07_52_04-SMath-Studio-0.99.7219---[Blatt5_].png)
SMath Studio: SMath Studio Desktop 0.99.7219.26345 portable, 64-bit
OS: Microsoft Windows NT 6.1.7601 Service Pack 1; Windows 7 Professional Service Pack 1, 64-bit
Screen: 1920x1080 px, 96x96 dpi, 96 GP.CDPI
Localization: language=ENG; dec.symbol=; arg.separator=; OS dec.symbol=; OS arg.separator=; OS d.g.separator=
Framework: CLR 4.0.30319.42000
installed versions:
v2.0.50727 2.0.50727.5420 SP2
v3.0 3.0.30729.5420 SP2
v3.5 3.5.30729.5420 SP1
v4
Client 4.7.02053
Full 4.7.02053
v4.0
Client 4.0.0.0
Plugins:
- [AppDir] Area Region - 0.99.7219.26345
- [AppDir] HTMLFileType - 1.14.7219.26345
- [AppDir] ImageFileType - 1.11.7219.26345
- [AppDir] Math Region - 0.99.7219.26345
- [AppDir] PictureRegion - 1.10.7219.26345
- [AppDir] PlotRegion - 1.11.7219.26345
- [AppDir] SMath Viewer Files Plugin - 1.1.7219.26385
- [AppDir] SMathFileType - 1.11.7219.26345
- [AppDir] SpecialFunctions - 1.12.7219.26345
- [AppDir] StandardToolboxButtons - 1.1.7219.26345
- [AppDir] TextRegion - 1.11.7219.26345
- [AppDir] XMCDFileType - 1.12.7219.26345
- [UserDir] Custom Functions - 1.1.7200.16172
- [UserDir] Custom Glyphs - 1.1.7200.16176
- [UserDir] Development Tools - 1.0.6974.21980
- [UserDir] Hyperlink Region - 1.0.7105.20106
- [UserDir] Image Region - 2.99.7100.21996
- [UserDir] Mathcad File Access Functions - 1.0.6983.32721
- [UserDir] MaximaPlugin - 1.98.7100.23756
- [UserDir] Nonlinear Solvers - 1.1.7097.23301
- [UserDir] ODE Solvers - 0.2.7155.3312
- [UserDir] PDF Files Plugin - 1.0.7097.27694
- [UserDir] Slider Region - 1.0.7100.22009
- [UserDir] Snapshot Region - 1.0.7100.22017
- [UserDir] Statistical Tools - 1.0.6824.32561
- [UserDir] Writer Region - 0.22.7200.15900
- [UserDir] XlsxImportExport - 1.3.6996.39330
- [UserDir] X-Y Plot Region (JXCharts) - 0.2.7198.38915
installed versions:
v4
Client 4.7.02053
Full 4.7.02053
v4.0
Client 4.0.0.0
Plugins:
Вячеслав Мезенцев 10/31/2019 2:04:00 PM
#37 Posted: 10/31/2019 2:05:49 PM
Updated and rebuilded for SMath Studio ≥ 0.99.7109.
#38 Posted: 6/29/2021 8:08:28 AM
I found that the following functions of this plugin are not working:
Play(), WRITEWAV(), GETWAVINFO(), READWAV().
I saw the problem inside the interactive SMath Handbook.
I have SMath Studio 0.99.7822 (01 June 2021) on win10.
Oscar
Oscar
Вячеслав Мезенцев 6/29/2021 9:47:00 AM
