Function called with matrix arguments get wrong answer
Function called with matrix arguments get wrong answer - Function called with matrix arguments get wrong answer - Messages
#1 Posted: 11/19/2012 10:22:33 AM
jmc
jmc
0 likes in 5 posts.
See the attached sheet.
The call to Vo() with matrix arguments should get the same answer as the individual evaluation, also included in the sheet, but it does not.
Vreg.sm (16 KiB) downloaded 1440 time(s).
#2 Posted: 11/20/2012 5:02:52 AM
No, it is not a bug - just a SMath feature. You divided a scalar (RU) with a matrix (RL), that is wrong. Reciprocal of a matrix gives its inverse, not the reciprocal of its elements as you wanted.
Please see the attached corrections
Vreg-corr.sm (20.21 KiB) downloaded 1465 time(s).
#3 Posted: 11/20/2012 6:24:32 AM
jmc
jmc
0 likes in 5 posts.
Thanks for the correction. This one might be a good addition to a Gotya section on the wiki if it is not already there.
