TextRegionUtilities - Could not load file or assembly 'WriterRegion
TextRegionUtilities - Could not load file or assembly 'WriterRegion - Cannot install or disable TextRegionUtilities - Messages
#1 Posted: 10/14/2021 6:54:45 AM
timgow
timgow
0 likes in 27 posts.
I wished to install TextRegionUtilities but this failed, now I can't enable or disable it from the local Plugins list.
Please help, I don't know the next move.
Tim
#2 Posted: 10/14/2021 8:21:56 AM
1,442 likes in 2,934 posts.
If you install WriterRegion everything should works as intended again.
#3 Posted: 10/14/2021 11:10:48 AM
timgow
timgow
Hello Davide,
Thank you for lookin at this issue.
WriterRegion is installed. I uninstalled WriterRegion, closed, installed WriterRegion, closed, reopened but unfortunately still get the error.
Tim
#4 Posted: 10/14/2021 11:14:36 AM
timgow
timgow
Davide,
The enable & disable were greyed out but I didn't realize that the dustbin was active; I deleted and reinstalled, all ok now.
Many thanks,
Tim
