Wrong display of output units
Wrong display of output units - Messages
#1 Posted: 10/18/2020 5:44:45 PM
EngMath
EngMath
0 likes in 51 posts.
I've just started using this software and I think that it's great. However, I came across an issue that may be a bug. Here's my input:
a := 0,1 m
b := 0,05 m
L := 1 m
M := 1000 Nm
τ_max := (2*M)/(π*a*(b^2)) =
Now in the last line I want to change units to MPa. But when I do it (by writing MPa in the right placeholder), I get the following result:
No matter what I try, I can't get rid of this part that I highlighted in red. I want to have just MPa on the right side. Is that a bug or am I doing something wrong ?
#2 Posted: 10/18/2020 5:54:25 PM
597 likes in 1,377 posts.
Nothing is wrong.
Could you please check your expressions carefully?
#3 Posted: 10/18/2020 5:59:32 PM
1,442 likes in 2,934 posts.
Perhaps you are using 'Nm instead of 'N*'m
If you want you can define your own torque unit 'Nm:'N*'m before the calculations, otherwise you have to multiply the force unit fot the length unit
EngMath 5/30/2021 9:05:00 AM
#4 Posted: 10/18/2020 6:02:47 PM
EngMath
EngMath
Problem solved, thank you very much. I had to type 'N*'m as you say because 'Nm wasn't recognized properly.
#5 Posted: 11/10/2020 8:35:58 AM
Int16
Int16
0 likes in 9 posts.
How to compute this
#6 Posted: 11/10/2020 12:20:49 PM
127 likes in 342 posts.
The problem is due to the internal storage of the program in Kelvin. You find several threads in the forum. you can also find an explanation in Martin Kraska's interactive guide (Tools menu -> Options -> Plugins -> interactive books). However the solution is to use DeltaC °
Davide Carpi 11/12/2020 10:10:00 AM
#7 Posted: 11/12/2020 9:04:06 AM
Int16
Int16
0 likes in 9 posts.
Thanks a lot.
#8 Posted: 11/12/2020 10:30:53 AM
... you can make the unit system silent, i.e: inactive
#9 Posted: 11/13/2020 5:55:49 PM
1,353 likes in 2,264 posts.
This is close to recommending pencil and paper.
#10 Posted: 11/14/2020 8:49:14 AM
Pretty close Martin, that's ± what QA sanity check does.
The mV/I temperature converter reads mV ... then displays °C.
In parallel to the black box mV/I, read mV, interpolate wrt NBS [now NIST].
#11 Posted: 11/14/2020 2:24:48 PM
wrong display of output units
You will have infinitely many of those, easy to doctor:
1. make the system silent, though not quite paper/pencil
2. make it user style at will.
