Select from file
Select from file - Messages
#1 Posted: 6/25/2015 5:09:58 AM
dansuciu
dansuciu
0 likes in 1 posts.
Hi there,
I have a large amount of initial data, that can vary depending on many conditions.
Each initial parameter has a set of parameters specific to it. i.e. concrete class C6/7.5 has a different compresive strength than C8/10 and so on
Of course, i want to create my algorithm as parametric as possible.
I was thinking of making some tabular data for them, but not sure if i can make smath read from another file, as to make the final file with results as clean as possible.
Any help or suggestion is appreciated.
Thank you.
#2 Posted: 6/25/2015 12:10:52 PM
Ernesto
Ernesto
13 likes in 74 posts.
You can try playing around with the ComboBoxList Extension. Attached is an example.
Expand the area to see the data I used.
Double click on the ComboBoxList region to see settings.
Davide Carpi 6/25/2015 3:05:00 PM
