¿How can i resolve this?
¿How can i resolve this? - Ecuation - Messages
#1 Posted: 8/20/2022 6:43:42 AM
R2022TC
R2022TC
0 likes in 1 posts.
I was triying to resolve this ecuation with "Maxima",But i dont now how to make it work,I have 2 vector with unkown components(0,y,z) and (0,g,n),and 2 forces with components unkown,but proporcional.¿
¿How can i resolve this kind of system?
Hoja de trabajo4.sm (139.92 KiB) downloaded 1378 time(s).
#2 Posted: 8/20/2022 8:14:35 AM
Laurent Fournier
Laurent Fournier
9 likes in 66 posts.
Here I have calculated the force resultant and decomposed in different directions, at several places.
No time to explain the details, but if you like you can use some of those methods.
It's just an application of the classic method.
There is some graphic representation of both forces and structural members, also.
Patharpratima Community Centre wind calculations 4-3-2022.sm (842.05 KiB) downloaded 1422 time(s).
#3 Posted: 8/20/2022 9:32:11 AM
Hoja de trabajo4.sm (148.39 KiB) downloaded 1359 time(s).
#4 Posted: 8/20/2022 10:13:08 AM
Laurent Fournier
Laurent Fournier
Oh my god it's a 3D system of forces. If you want to solve in 3D you will get screws/wrenches, it's terribly complicated to resolve. I did once in geogebra, it works but it's so involved I didn't have the courage to translate to Smath. A more elegant way than solving 3D screws would be to work with polar polyhedra (see the PhD of Marina Konstantatou). I also did that in geogebra, and here also, couldn't find teh courage to translate to Smath. But it would be very exciting if someone could do that, because geogebra is very limited in the size of data it can handle because of its interactive mechanism.
So anyway, for a practical solution, in your place I would work in 2D projections of the 3D forces. 2 projections are enough. It's absolutely fine for engineering purposes in my (limited) experience.
#5 Posted: 8/20/2022 10:18:15 AM
Laurent Fournier
Laurent Fournier
https://www.geogebra.org/m/vkzdc68w
https://www.geogebra.org/m/es2abqgd
https://www.geogebra.org/m/euy4yaqw
https://www.geogebra.org/m/fdmgsqyy
Some practical examples and some useful academic references for solving forces in 3D
#6 Posted: 8/20/2022 8:22:51 PM
1,139 likes in 1,805 posts.
Hola Erre. You can have a lot of issues trying to solve your system with maxima because that the decomposition over components isn't automatic in SMath.
In the attached a numerical method implemented for solve the system, which depends of the guess value, as usually do any numerical method.
Hoja de trabajo4.sm (151.06 KiB) downloaded 1372 time(s).
Hoja de trabajo4.pdf (536.71 KiB) downloaded 820 time(s).
