Units and Control Boxes
Units and Control Boxes - How to set units for output variables of control boxes? - Messages
#1 Posted: 2/12/2018 1:55:07 PM
João Felipe Seráfico Melo
7 likes in 62 posts.
Hello!
If I have a slider or checkbox, is there a way to define the units for my output variable directly on the settings?
I can handle units outside those just fine, but I'd really like to get my variables with their units right from the boxes.
Sorry if it's a stupid question.
Thanks in advance!
#2 Posted: 2/12/2018 3:02:36 PM
hello [userlink]JoãoBR[/userlink],
is not possible, neither for visualization inside the control itself.
One day, maybe (need to figure out something to be applied in generic cases, mixed units in the input matrix)
#3 Posted: 2/12/2018 4:21:41 PM
Thank you, Davide. It's really a pitty.
Let me ask you this, then:
I want a variable like "fck" in MPa, and build a slider to set something like "Set_fck", how could I make "fck" get "Set_fck" numerical value but keeping it in MPa?
#4 Posted: 2/12/2018 4:48:19 PM
Arie
Arie
94 likes in 285 posts.
Is this what you're asking for?
fck.sm (2.58 KiB) downloaded 1312 time(s).
Andrey Ivashov 2/12/2018 11:32:00 PM, Davide Carpi 2/13/2018 4:41:00 AM
#5 Posted: 2/12/2018 7:48:20 PM
Yes, alyles, that's it, but I can't do it for some reason.
I've tried typing the apostrophe and using the CRTL+W shortcut, but the unit selection option just doesn't appear.
These methods work just fine when I create a new variable.
#6 Posted: 2/12/2018 10:52:06 PM
Done it! CTRL+W and using the apostrophe did not work, but *MPa+TAB did the job.
Thank you all
