Boolean less than and greater than
Boolean less than and greater than - difficulty using < and > - Messages
#1 Posted: 1/29/2014 12:27:21 PM
MrGreen
MrGreen
0 likes in 2 posts.
hi there,
I've just started using smath for a uni project,and i am trying to get an answer not to exceed a particular amount, i was hoping that you guys might have a method, tips or tutorial to explain it.
thanks in advance
#2 Posted: 1/30/2014 4:47:15 AM
1,440 likes in 2,929 posts.
Hi Mr Green,
You can use booleans and programming functions (if/else) to check if your answer fit your target.
On the wiki you can found an example (here) and also a lot of tutorials and examples about using SMath Studio.
Moreover, there are plugins to extends these features:
- CF Label plugin
- Functions' Extensions
#3 Posted: 1/30/2014 4:48:18 AM
Hi Mr Green,
- CF Label plugin
#4 Posted: 2/19/2014 10:08:21 AM
MrGreen
MrGreen
0 likes in 2 posts.
thanks very much
#5 Posted: 2/19/2014 1:50:51 PM
1,350 likes in 2,262 posts.
you might just use [MATH]Min(whatever_you_get;upper_limit)[/MATH]. The lowercase function [MATH]min(#)[/MATH] works as well but just takes a single vector or matrix argument.
Davide Carpi 2/19/2014 2:35:00 PM
