Rope
Rope - Messages
#1 Posted: 3/26/2024 5:52:29 PM
Valery Ochkov
Valery Ochkov
66 likes in 696 posts.
How can we solve this task in SMath?
3-mass.pdf (313.91 KiB) downloaded 782 time(s).
#2 Posted: 4/9/2024 1:07:47 AM
StvMath
StvMath
44 likes and 1 dislikes in 71 posts.
I decided to have some fun by trying to solve this using only SMath basic capabilities. I found it easier to turn everything upside-down (i.e. to pretend that gravity pulled up instead of down!) and only reverted to the normal view when plotting the position graphs.
I used an ultra-simple approach based on getting three sets of guesses for each mass coordinate and iterating until their differences were smaller than my specified tolerance. It’s crude, but it worked!
Life would be much simpler of course if SMath had its own minimize or maximize function.
3_weights_stvmath.sm (37.05 KiB) downloaded 1506 time(s).
Valery Ochkov 4/9/2024 2:40:00 AM
#3 Posted: 4/9/2024 3:08:28 AM
Valery Ochkov
Valery Ochkov
>Life would be much simpler of course if SMath had its own minimize or maximize function...
...with constrains.
#4 Posted: 4/9/2024 2:52:23 PM
Valery Ochkov
Valery Ochkov
#5 Posted: 4/9/2024 4:25:15 PM
StvMath
StvMath
Posted
Yes. In the loop where it checks for unacceptable y2 values I should have added the line, msg:="Unacceptable y2 values. Try different initial guesses".
Additionally, by changing lambda = lambda/2 to lambda = -lambda, it seems to work ok!
If you change the initial guess for y2 to 11.5 it also works ok.
Note: The method is very crude. It won't work for more than three weights, for example, without significant modification.
#6 Posted: 4/13/2024 11:07:21 PM
StvMath
StvMath
I'm still playing with this example!
The attached uses a force-based approach, rather than an energy=based one.
I couldn't figure out how to use the in-built Jacobian functions for my forces function, so had to construct it by hand (luckily, it's a very simple task here).
3_weights_stvmath_b.sm (38.45 KiB) downloaded 1439 time(s).
3 users liked this post
Oscar Campo 4/13/2024 11:59:00 PM, Valery Ochkov 4/14/2024 2:16:00 AM, ioan92 4/14/2024 2:54:00 AM
