how can I fill a matriX
how can I fill a matriX - Messages
#1 Posted: 6/21/2021 3:48:49 PM
mnorena
mnorena
0 likes in 13 posts.
Hi, can someone help me with the solucion of this problem that i have, I need to create a matrix with the vector "t" in the first column and in the first row with the values ​​of "T1, T2..T6", and the matrix has to be filled with the equation "I".
FINALLY I HAVE TO GRAPH IN THE X-AXIS THE VALUE OF "t" AND IN THE AXIS AND THE VALUES THAT I FIND OF "I" FOR EACH "T1, T2 ... T6". IS IT POSSIBLE THAT THE CURVES ARE IN THE SAME GRAPHIC? LIKE THIS
#2 Posted: 6/21/2021 11:02:53 PM
598 likes in 1,380 posts.
- Here is your table calculated with algorithm
- It is possible to plot multiple entities
matrix.sm (15.56 KiB) downloaded 1085 time(s).
#3 Posted: 6/22/2021 11:22:47 AM
mnorena
mnorena
THANKS FOR YOU HELP
#4 Posted: 6/22/2021 11:30:10 AM
mnorena
mnorena
I AM TRYING TO DO IT, BUT WHEN I CREATE THE TABLE IT DOES NOT SHOW ME THE RESULTS ONLY THE EQUATION LIKE THIS,
CAN YOU TEACH ME HOW I DO IT PLEASE??, THANK YOU
#5 Posted: 6/22/2021 12:06:02 PM
I have done nothing special. It seems your table is shown as optimization-none.
I didn't know if there is an option for this, however your pc made it possible.
Update your smath and plugins to the latest version. Watch the video below.
If it doesn't work as it is shown, then this is a bug. File a bug report.
#6 Posted: 6/22/2021 12:27:44 PM
mnorena
mnorena
I found the error, thank you so much
#7 Posted: 6/22/2021 2:20:06 PM
... updated
Page8 Marcela.sm (20.61 KiB) downloaded 1203 time(s).
#8 Posted: 6/22/2021 2:37:18 PM
I am just wondering, what was the error?
Could you please explain?
