Ignore units or Error: Result is above max.allowed positive number
Ignore units or Error: Result is above max.allowed positive number - Messages
#1 Posted: 12/15/2015 4:19:07 PM
archbuilder
archbuilder
0 likes in 4 posts.
Hello community,
with activated units the evaluation of a expression in my sheet is aborted with the error:"Result is above max.allowed positive number". If units for the sheet are deactivated the expression is evaluated, but the result is different.
units deactivated:
Changing the evaluation to numeric does not change the behaviour - I followed the discussion here: Result-is-above-max-allowed-positive-number.
Do you have general advice to resolve the issue of the aborred evaluation of the expression?
If necessary I would send smath-file via Email (work in progress for a publication*).
Bye
radex
Ps.: @community here - thank you for smath and all the great plugins
*will late be published as a tutorial
#2 Posted: 12/15/2015 9:30:50 PM
Post the work sheet, that will help.
on't use unit from the menu. Define separately,
plug in the place holder.
#3 Posted: 12/16/2015 9:45:41 AM
1,442 likes in 2,934 posts.
Without the worksheet is really hard to understand where may be the issue...
Have you tried to force a partial numeric evaluation in either the numerator or the denominator using eval(#)?
