Hello dear Smath community...
I've been working on a sheet to calculate the interaction diagram of a column, however I'm not really good with programing and It's been quite a struggle to figure out how to get the graph I'm looking for. I know that the equations I've written are correct but the commands to translate the different parameters into a graph are failing for sure, since it requires to evaluate each value of a vector and I don't understand how to make my functions to do exactly that. Please if you guys could give me a hand with it by checking the code and pointing to me where are my mistakes or how could I optimize the code I'd greatly appreciate it.
I've attached my smath worksheet for you guys to have a look. Thank you!
Diagrama de interaccion.sm (53.75 KiB) downloaded 1843 time(s).
