Solving overdetermined systems of linear equations
Solving overdetermined systems of linear equations - Messages
#1 Posted: 11/25/2016 4:08:21 PM
Brian Runagle
Brian Runagle
13 likes in 27 posts.
I was reminded by the posts in, New variable programmatically; also: Solving under/over defined system of linear eqautions,
that I'd recently used an algorithm for overdetermined systems that I'd unearthed in Wikipedia:
I've documented it's use very simply so that even I'll know how to use it next time it's needed. (memory gets a lot worse with age ) Perhaps others will find it useful.
https://smath.com/wiki/GetFile.aspx?File=LinearEquationSystems.sm
Brian
3 users liked this post
frapuano 11/25/2016 4:27:00 PM, Alexander O. Melnik 11/25/2016 6:09:00 PM, Davide Carpi 11/25/2016 7:18:00 PM
#2 Posted: 11/25/2016 6:11:04 PM
Alexander O. Melnik
Alexander O. Melnik
127 likes in 498 posts.
Thanks alot; always good toclean up a worksheet from unnecessary plugin calls.
#3 Posted: 11/25/2016 7:52:59 PM
The β snippet represents the 'Cholesky' solver, used directly
for fitting polynomials to noisy data set. It is also the basic
solver in association with the "Conjugate Gradient".
bdrunagle 11/26/2016 4:57:00 AM
