Natural fractions
Natural fractions - How can I enter a value to display the integer and fractional part - Messages
#1 Posted: 10/21/2022 4:00:17 AM
Юрий
Юрий
0 likes in 1 posts.
Natural fractions. How can I enter a value to display the integer and fractional part, like 2½. Maybe somewhere there is a full-fledged Help?
#2 Posted: 10/21/2022 7:59:41 AM
Natural fractions.
... Maybe like this
#3 Posted: 10/21/2022 10:42:57 AM
⚜ Kenny Lemens, P.E. ᵂᴵ
85 likes in 181 posts.
Greetings!
I understand your question, but such a feature isn't built into SMath. However, there are ways to mitigate this lack of support.
If you wish for special characters (e.g., 「½」) to be treated as a number, you can declare then as such:
½:0.5
      There are a few of these fraction characters you can define as a variable:
If you wish to type a fraction in as you propose (2½ ), this isn't so easy. You can use a matrix and then add the values together (i.e., Σ[2 ½]). This reads kinda like a fraction, but is needlessly bulky:
sum(mat(2,½,1,2))
If the goal is to have the result of 2.5 itself to report as 2½ instead of 5/2; there isn't much you can do. The one thing you can do is create a function that will convert your number and report that fraction as type "string"
Hope this helps!
#4 Posted: 10/21/2022 11:49:46 AM
churichuro
churichuro
29 likes in 79 posts.
easy
2+1/2
#5 Posted: 10/21/2022 11:57:51 AM
Natural fractions.
... make it algo style utility.
#6 Posted: 10/21/2022 12:15:46 PM
Oscar Campo
Oscar Campo
135 likes in 309 posts.
Maybe this can help:
dec2frac.sm (6.59 KiB) downloaded 1263 time(s).
Alvaro 10/24/2022 12:51:00 AM
#7 Posted: 10/22/2022 8:55:34 AM
Natural fractions.
... lat brick in the wall from not acknowledged.
Stuff Forum.sm (12.14 KiB) downloaded 1323 time(s).
#8 Posted: 10/24/2022 9:55:59 PM
Norm Schutzkus
Norm Schutzkus
9 likes in 90 posts.
"dec2frac(decimal)" Works for me! Thank you! I've been using a sheet from MathCad, which is not as clear:
Feet Inches and Fractions.sm (38.21 KiB) downloaded 1244 time(s).
Alvaro 10/25/2022 1:12:00 AM
#9 Posted: 10/25/2022 1:17:33 AM
1,138 likes in 1,805 posts.
Even the Oscar's solution is very elegant, this is another approach, based on the Nasch work.
Feet Inches and Fractions.sm (40.62 KiB) downloaded 1292 time(s).
Feet Inches and Fractions.pdf (166.57 KiB) downloaded 872 time(s).
As an application, using a vernier (the English version here, but without the students comments)
