This is my first attempt at using SMath for structural design. I would appreciate somebody trying it out and providing any feedback on any errors or questions
KCA Structural Steel Sections 2.sm (71.97 KiB) downloaded 1368 time(s).There are a few analysis snippits on this forum but none really for design in accordance with codes and British Standards so I thought I would try to address that.
There are only 4 beams to choose from initially, but it is fairly straight forward to add more (although you have to change the page size to A3 landscape to work on the matrix)
The design requires a choice of whether the assessment checks a beam spanning between supports, between support and a restraint or between restraints. The items in green are for user input or connection to an early analysis page. The item in blue (user input) is used instead of span, only if the choice was to check a portion of a beam between restraints or restraint and support
Thanks to Andrey and his team for this package, this is far better than Mathcad
