... same as before with a bit more doctoring.
You got the 3 types, strictly identical to known CAS
[Mathcad, Matlab ...]. So, you get the first & 2nd
derivatives. 1rst deriv is scalar, 2nd is discrete.
The spline function is scalar as well.
Remenber: the spline function and the 1rst derivative
don't support Smath derivative operator. No problem
working projects whereas "splines" are not interpolating
functions, only usable as discrete output, same as Mathcad.
Resume: Spline(x) & D(x) are interpolatable on-line
for 2nd deriv you have to linterp for on-line interpolation.
Hello Radovan: that should you make you happy.
Cheers all collabs.
Spline l_p_c [Suite].sm (116.05 KiB) downloaded 1315 time(s).
