Symbolic result for sum(#)
Symbolic result for sum(#) - Messages
#1 Posted: 7/5/2020 7:17:35 PM
1,125 likes in 1,798 posts.
Hi. sum have an issue for symbolics evaluations.
#2 Posted: 7/5/2020 7:36:36 PM
Just check , Alvaro.
Between yourself and me ... we are old kookoo in those games !
#3 Posted: 7/5/2020 8:51:36 PM
598 likes in 1,380 posts.
You are correct, bug reproduced.
Definitely there are some issues.
Perhaps it is not only sum related too.
Alvaro 7/6/2020 3:46:00 AM
#4 Posted: 7/6/2020 3:45:56 AM
Hi. Thanks Overlord. I don't see these other problem. What make troubles for me is the fact that sum don't returns the symbolic values but numerical approximations, in this case for sqrt(17). I expect to see sum(vec) = 5/sqrt(17) instead the rational showed. I introduce the "x" value just for check if sum have some eval() function somewhere. But then ... ups, another issue simplifying 1+4.
#5 Posted: 7/6/2020 4:00:32 AM
1,357 likes in 2,271 posts.
sum.sm (11.67 KiB) downloaded 1389 time(s).
Alvaro 7/6/2020 12:49:00 PM
#6 Posted: 7/6/2020 7:17:28 AM
I see no bug ...
NOBUG.sm (30.88 KiB) downloaded 1319 time(s).
#7 Posted: 7/6/2020 12:48:31 PM
Hi. Some notes attached.
sum.sm (20.39 KiB) downloaded 1337 time(s).
sum.pdf (66.13 KiB) downloaded 706 time(s).
#8 Posted: 7/7/2020 7:34:39 AM
