Radians to degrees?
Radians to degrees? - trigonometri - Messages
#1 Posted: 12/6/2012 8:28:27 AM
Kasperhaack
Kasperhaack
0 likes in 2 posts.
Im working with trigonometry, how do I get the cos and sin functions to return the result i degrees?
#2 Posted: 12/6/2012 9:24:29 AM
1,440 likes in 2,927 posts.
Hi [userlink]Kasperhaack[/userlink]
To show or to customize an output unit you must type the apostrophe on the placeholder in the right side of the equation, and then you can type the unit ° or you can choose one from the list that appear (the dynamic assistance box).
EDIT: see also UNITS ON WIKI
regards,
w3b5urf3r
#3 Posted: 12/6/2012 11:11:00 AM
Oscar Campo
Oscar Campo
135 likes in 309 posts.
Kasperhaack,
In the same way you can use degrees inside trigonometric functions:
cos(45° )=0.7071
Oscar
#4 Posted: 12/10/2012 6:58:30 AM
Kasperhaack
Kasperhaack
0 likes in 2 posts.
Thank you guys!
#5 Posted: 5/8/2013 6:29:38 AM
122 likes in 340 posts.
looks like they're back problems with degrees in 0.96.4875 version.
such as "cos (45°)" does not work in numeric mode
#6 Posted: 5/8/2013 6:57:58 AM
works for me (win7 x64)
#7 Posted: 5/8/2013 7:11:47 AM
from me no
win7 64
[albumimg]120[/albumimg]
#8 Posted: 5/8/2013 8:05:51 AM
It works for me as well
Win7 - 64
#9 Posted: 5/8/2013 8:38:00 AM
from me no
win7 64
Qual'è il messaggio di errore? Puoi postare questo file?
What's the error message? Can you share this file?
#10 Posted: 5/8/2013 9:28:25 AM
Oscar Campo
Oscar Campo
from me no
win7 64
Hi Sergio, what is the error message from SMath in the "cos(45° )= " in numeric mode?
Oscar
#11 Posted: 5/8/2013 10:13:56 AM
The PC reboots everything works correctly
I remember that the problem occurred after testing Radovan files with two files that interfere "No_units_used.sm" and "Units_dont_mathc.sm"
I think it's related to that problem but I did not understand in what way.
As written by Ioan there may be a problem internal memory management to Smath
Per Davide (se ciò che ho scritto sopra è gravemente scorretto per favore correggimi)
Al riavvio del PC tutto funziona correttamente.
Ricordo che il problema è avvenuto dopo aver testato i file di Radovan con i due files che interferiscono "No_units_used.sm" and "Units_dont_mathc.sm"
Credo che sia legato a quel problema ma non ho capito in quale maniera. Come scrive Ioan potrebbe esserci un problema di gestione della memoria interno a Smath
#12 Posted: 5/8/2013 10:36:47 AM
Ok, I understand; this permeability is not good . However remember that SMath Studio 0.96.4875 is a "nightly build" (a beta, in practice ) so could cause some issues....
Ok ho capito, queste interferenze tra files non mi sembrano una buona cosa. Comunque ricorda che l'ultima versione è una "nightly build" (una beta, fra l'altro è stata postata solo nella sezione inglese del forum e in una sotto-sezione a parte) quindi è facile che contenga errori.
best regards,
w3b5urf3r
sergio 5/8/2013 11:04:00 AM
