Palette suggestions
Palette suggestions - Palette Suggestions - Messages
#1 Posted: 3/15/2018 10:12:47 PM
1. Replace backspace by the conjugate operator.
2. Plot: conserve points/lines, remove others
...add Smath 3D, Maxima X_Y ,,, maybe plotG(,)
3. The range Summation is desirable
4. The vector Sum is desirable.
5. Undefined integrator is desirable
6. 'n' derivative is desirable.
7. if/else, if/otherwise
[some maths don't accept if/otherwise]
8. Insert Image
9. Insert Writer region
10. Insert Area/Separator
Few more work sheet functionalities ?
1. Shift, click on sparse regions to select
2.
3.
Enhancing Smath is another story.
  • New Posts New Posts
  • No New Posts No New Posts
