Solve() throws "No real roots"
Solve() throws "No real roots" - Polytropic Calculation - Messages
#1 Posted: 12/8/2017 2:59:19 PM
usamakhan
usamakhan
7 likes in 98 posts.
I am using the latest version of Smath Studio & have seen many other threads on this forum regarding similar issue. I don't want to use xMaxima addin because of portability issue with Maxima distribution. If some however can provide a link to portable Maxima package it will be greatly appreciated
Coming back to the issue please see the attach file as my solve command for polytropic compressor calculations fails. Equations does include units ...from a preview (tooltip) of eq2 I see no problem but solve() throws error
Page1.sm (7.77 KiB) downloaded 1389 time(s).
#2 Posted: 12/8/2017 4:11:08 PM
Arie
Arie
94 likes in 285 posts.
You really don't need to use the solve function here as you already have an expression for power. Consider pre-defining eq.2 and simply evaluating it as needed as shown in attached. Page1.sm (9.83 KiB) downloaded 1512 time(s).
#3 Posted: 12/8/2017 11:05:48 PM
construct the right way, like this.
Ioncube.sm (11.16 KiB) downloaded 1324 time(s).
#4 Posted: 12/11/2017 1:29:36 PM
usamakhan
usamakhan
Thanks for the great help guys. Much appreciated. Can I ask one more thing (because I have prior experience to Geogebra)
In my file lets assume that I want to see the effect of increasing T2 upon CompressorPower as well as Efficiency ....a graph will suffice! Back in Geogebra I would have created a list of T2 (from say 160 to 300 with 10 as increment) & would get the calculated parameters also in a list ...these lists will then be converted to coordinates (x,y via list to matrix manipulation) & will be ready for plot
#5 Posted: 12/11/2017 4:16:55 PM
Arie
Arie
This is one way to do it. Page1 (2).sm (8.31 KiB) downloaded 1473 time(s).
#6 Posted: 12/11/2017 5:52:04 PM
Just like this => solve for n as many as you wish
Administrate the remaining of the project at will wrt those n
Cheers mon ami.
Ioncube.sm (17.26 KiB) downloaded 1209 time(s).
#7 Posted: 12/12/2017 11:34:50 AM
usamakhan
usamakhan
Thank you alyles & Jean, I am really liking it more than even my favorite Geogebra
Jean can you please explain a bit more about this portion
http://prntscr.com/hmhz8g
