Data lost when you delete the first line of an Area Region
Data lost when you delete the first line of an Area Region - Messages
#1 Posted: 3/5/2014 1:03:29 PM
Ryan Freund
Ryan Freund
20 likes in 339 posts.
I can't quite figure out the set of circumstances which apply when this happens but I seem to lose the bottom portion of a calculation when I save or maybe when I close out of a document. I'm not sure where the "split" occurs but the document does contain multiple separators, images and areas.
I am using Smath Travel version so I'm not sure if it applies to both. The travel version is stored on dropbox and so is the saved document.
If I go back in the previous versions saved on dropbox it appears that this happens if you insert an Area then delete the top line of the area and leave the bottom line. I must have done this accidentally but none the less it seems you lose all the data below the bottom area line.
Is this correct? or maybe there is something else going on.
Thanks,
Ryan
ioan92 3/5/2014 2:10:00 PM, Davide Carpi 3/18/2014 10:00:00 AM
#2 Posted: 3/16/2014 7:14:49 PM
Original post by RFreund here
I seem to lose the bottom portion of a calculation when I save or maybe when I close out of a document. I'm not sure where the "split" occurs but the document does contain multiple separators, images and areas. [...] if you insert an Area then delete the top line of the area and leave the bottom line. I must have done this accidentally but none the less it seems you lose all the data below the bottom area line.
(reproduced in the attachments)
Best regards,
Davide
[Moderator: uni] it was my fault. I moved and lost messages.
MOVED IN THE BUG TRACKER
end file.sm (1.97 KiB) downloaded 1349 time(s).
ioan92 7/17/2014 9:12:00 AM
#3 Posted: 7/17/2014 7:07:16 AM
Ryan Freund
Ryan Freund
I voted for a couple "Area handling" issues in the bug tracker but does anyone know if this one is in the tracker?
I'd like to name this one the kiss of death or maybe "good morning surprise" would be a more accurate description... very easy to miss (not to mention frustrating) if you are dealing with many separators and areas.
#4 Posted: 7/17/2014 7:11:53 AM
My fault, I've forget to post the link: SS-2
Best regards,
Davide
