Beta: SMath Studio 0.99.7202 (20 September 2019) - Messages
Changes introduced in current build 0.99.7202
Corrections
- SS-4603: Index out of bounds issue fixed happened sometimes on displaying calculation results;
- Back-compatibility improved for worksheets which contains TableRegion with custom options;
- Work with big and small numbers improved;
- Dialog for installing required plug-ins implemented for children Regions;
- Text formatting shortcuts supported for children Regions now.
Download
SMathStudioDesktop.0_99_7202.Mono.tar.gz (1.4 MiB) downloaded 2579 time(s).
SMathStudioDesktop.0_99_7202.Setup.msi (2.27 MiB) downloaded 5058 time(s).
ChildrenRegions.pdf (187.22 KiB) downloaded 1115 time(s).
Word wrap in text regions is great!
The new children mechanism seems to provide a lot of options. First of all I think of plot regions with axis limits and expressions being handled much like in Mathcad.
An interesting option is to provide language-specific definitions, as the contents of a text region including all children can be language-specific. In the past I did this in the Maxima-Plugin-Test using the value of math region descriptions. In fact, you can provide localized definitions by putting math regions inside otherwise empty text regions.
Martin
WroteFirst of all I think of plot regions with axis limits and expressions being handled much like in Mathcad.
You mean as a new 2D plugin, that will plot crappy traces
as crappy as Mathacd caused by imposed limits, whereas it
won't plot on pixels anymore. Mathcad plots on ½ pica.
and can about never plot 2 plots of equal height/width.
Argument style is debatable. Older SS does not open
most latest versions. Good idea to relax the old wolf
from reading same paper [same Smath document] as the youngest ones.
Smath handles the X, Y directions by pixels,
Mathcad handles in ½ pica.
