Integration problem with user defined function with units in Latest SS 0.99.6877
Integration problem with user defined function with units in Latest SS 0.99.6877 - Messages
#1 Posted: 10/30/2018 11:16:55 PM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
Thank you Andrey for the latest SS 0.99.6877.
However, I observe a problem in integrating a user defined function with units.
The attached SS document (and all similar docs) worked fine in all previous SS versions without any issue.
Malwala Reservoir Flood Capacity Estimation-Simple.sm (249.34 KiB) downloaded 1394 time(s).
sergio 10/31/2018 5:16:00 AM
#2 Posted: 10/31/2018 3:23:38 AM
2,345 likes in 4,059 posts.
Thank you!
For some reason I had no automated test with such example (integral with units) and that is why I didn't catch this error before the latest beta release.
Will add example to tests and make a fix asap.
Thanks for the report!
Arie 10/31/2018 10:30:00 AM, NDTM Amarasekera 11/5/2018 12:56:00 PM
#3 Posted: 11/6/2018 10:45:46 PM
NDTM Amarasekera
NDTM Amarasekera
Thank you Andrey for the fix.
Andrey Ivashov 11/7/2018 2:31:00 AM
