Beta: SMath Studio 0.99.6858 (11 October 2018)
Beta: SMath Studio 0.99.6858 (11 October 2018) - Messages
#1 Posted: 10/10/2018 7:54:46 PM
2,343 likes in 4,055 posts.
Changes introduced in current build 0.99.6858
Improvements
  • Added support for Header/Footer (see Insert > Header/Footer menu items or use doubleclick on Header/Footer area to activate editing; press ESC or doubleclick on page content to return back);
  • Implemented support for Fields (auto-fields) inside MathRegion (see Insert > Field... dialog);
  • Added ability to Fill background image to the page bounds;
  • Background image can now be shown in full page size;
  • MathRegions consists with single variable name contains special symbols automatically switches cursor to Special Chars mode on focus.
Corrections
  • Fixed issue happens on drawing cursor after space symbol in MathRegion;
  • Incorrect pages numbers used in Insert Background dialog fixed for Pages layout mode;
  • Fixed observation happens on inserting operator inside of the variable name which contains special symbols;
  • SS-3567: Saving of worksheets with protected collapsed Areas fixed.
Miscellaneous
  • Refactoring.
Download
SMathStudioDesktop.0_99_6858.Mono.tar.gz (1.34 MiB) downloaded 2646 time(s).
SMathStudioDesktop.0_99_6858.Setup.msi (2.21 MiB) downloaded 5522 time(s).
9 users liked this post
Вячеслав Мезенцев 10/11/2018 4:24:00 AM, Davide Carpi 10/11/2018 4:25:00 AM, frapuano 10/11/2018 5:10:00 AM, NDTM Amarasekera 10/11/2018 5:10:00 AM, sergio 10/11/2018 5:15:00 AM, Arie 10/11/2018 8:35:00 AM, overlord 10/12/2018 12:46:00 PM, Denis Nikitin 10/16/2018 2:24:00 AM, Serg 10/18/2018 3:10:00 AM
#2 Posted: 10/12/2018 1:38:12 PM
600 likes in 1,381 posts.
New header-footer option is awesome. This will help me to reduce file sizes a lot.
By the way I noticed the linux and windows versions have layout difference.
Same file opened in SMath (6853) via "Arch Linux" an "Windows 10" has misaligned regions.
Regions under Linux are wider and pictures regions are bigger I guess.
I use cups-pdf to preview under Linux if it will help and I just noticed I can't print to pdf. But I can preview it.
Regards.
#3 Posted: 10/14/2018 6:28:42 AM
ianlh
ianlh
0 likes in 38 posts.
On this latest version (mono), when selecting the units, the box only fills with the first. when required to use a different unit you can move down, but nothing is shown apart from the help/hint box.The Linux version i am using is Mint 18.3.
#4 Posted: 10/15/2018 4:01:30 PM
1,361 likes in 2,275 posts.
There is no "Field" entry in the Text_Eng.lang file (for Insert> Field).
#5 Posted: 10/17/2018 2:42:38 PM
Alexander O. Melnik
Alexander O. Melnik
127 likes in 498 posts.
Thank you for great formatting updates!
May I place a request please? It is often useful to record a date calculation page was created on. Is it possible to have a date field that is updated only when it is created or copy pasted instead of being continiously updated when file is opened or reloaded?
Thanks!
#6 Posted: 10/17/2018 6:14:08 PM
Arie
Arie
94 likes in 285 posts.
Thanks!
In the meantime, You could manually achieve this by right-clicking date field and choosing "disable evaluation" after the file is created the first time. Re-enable, reevaluate sheet, then disable anytime you recopy file or want to update the field. .
sergio 10/18/2018 4:55:00 AM
#7 Posted: 10/18/2018 6:00:08 PM
May I place a request please? It is often useful to record a date calculation page was created on. Is it possible to have a date field that is updated only when it is created or copy pasted instead of being continuously updated when file is opened or reloaded?
Interesting request, but between the moment a work sheet is first created
and the last saving [dozen and dozen times saved], the first time saved
has no more meaning: is it ?
Windows timestamp [hover on sheet name] is the last saved.
Print preview page header is the actual time
#8 Posted: 10/19/2018 12:46:24 PM
Farja
Farja
1 likes in 7 posts.
I know the limitations for importing Mathcad files. I have used it in the last couple of months without much trouble to partially import old mathcad sheets.
But, i get this error with the latest version: "Object reference not set to an instance of an object."
Thanks!
#9 Posted: 10/21/2018 9:06:25 AM
Kizilcay
Kizilcay
0 likes in 4 posts.
I observed the same error with the same Smath Studio version on Windows 8.1 (German). The message appears in German:
"Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt".
Should I try to reinstall version 0.99.6839 - Stable (released at 2018-09-22) - recommended?
Thanks for the help in advance.
Mustafa
#10 Posted: 10/21/2018 9:15:00 AM
Kizilcay
Kizilcay
0 likes in 4 posts.
Just an update to the above error message. I uninstalled the latest beta version and installed the last stable version 0.99.6839. The problem was solved. I can open/import Mathcad files (.xmcd).
#11 Posted: 10/26/2018 2:55:58 PM
Thanks!
Thank you for the report. Issue is fixed now. Fix will be available into the next beta release.
Best regards!
