Hi, the attached sheet defines a simple function Qout(Qin) based on if statements.The function works for single valves of Qin.However, I'd like to plot Qout(Qin) so I defined Qin as a range variable.The function doesn't work and gives me a type conversion error.I'm a newbie to smath, please can you advise what I'm doing wrong?I've been through the documentation and examples and can't find anything.
That's as far I understand the problem. It needs more fabrication.
It should work in your latest Smath. If you have more interest,
I can probably find a model function to the pump curve.
As your are nwe in Smath Community: please, do not hesitate.
pump station2.sm (21.29 KiB) downloaded 1174 time(s).
