Temperature [-273.15 ... 1084.5 °C]
Temperature [-273.15 ... 1084.5 °C] - Temperature [-273.15 ... 1084.5 °C] - Messages
#1 Posted: 2/7/2019 10:55:35 AM
These 3 Smath documents are minimalist: Scientific/Engineering/Edu.
1. Germanium sensors as Secondary Standard ... as delivered
2. Pt sensors as Primary Standard [check more for their range].
3. Thermocouples T/C types T, J for industrial applications.
You may afford an household cheap thermometer.
In 1977, the Nuclear Power Plant I used to work had several
temperature points @ 10000 $ each ... just a peanut !
Enjoy those calculators ... any questions ?
Inst_Type T_J NBS 125 Copy.sm (117.66 KiB) downloaded 1306 time(s).
Inst_Type Ge Copy.sm (220.72 KiB) downloaded 1297 time(s).
Inst_Type Pt100 Reconciliation Copy.sm (536.74 KiB) downloaded 1314 time(s).
#2 Posted: 2/11/2019 10:55:40 PM
... this document reconciliates the previous Pt100 Calculator.
1. It is all inclusive for tracability
2. Guidance for calibrating the loop.
3. eit90 decimals respected.
Inst_Type Pt100 CALCULATOR Copy.sm (108.49 KiB) downloaded 1293 time(s).
