1 Pages (4 items)
Matrix Mirror - Matrix Mirror - Messages
#1 Posted: 9/9/2016 9:29:52 AM
Smath does not support reverse cols order in "submatrix".
Alternately, here is the module. Read more in the attached.
Utilities Matrix Mirror Exercise.sm (19.08 KiB) downloaded 1423 time(s).
#2 Posted: 9/9/2016 11:06:05 AM
I think this is remedied as well with the recent vector indices.
Moreover, I think we can forget about submatrix() function now
http://smath.info/cloud/worksheet/uRMs2euU
#3 Posted: 9/9/2016 12:33:23 PM
You even don't have to wait for the vector indices, at least for the mirror.
See here
The mirror implementation is straightforward to understand (transpose, reverse, transpose)
The diagonal is a nasty indexing trick, which is that far from paper and pencil notation that it can't be recommended unless you want to obfuscate your algorithm (then best use excel). You just square the row/column index range elements to access the diagonal elements in linear indexing.
This, however, uses the vector index feature.
See here
frapuano 9/9/2016 2:23:00 PM
#4 Posted: 9/10/2016 3:38:55 AM
WroteThe diagonal is a nasty indexing trick, which is that far from paper and pencil notation that it can't be recommended unless you want to obfuscate your algorithm (then best use excel). You just square the row/column index range elements to access the diagonal elements in linear indexing.
diagonal(M):el(M,(range(0,(rows(M)-1)))*(rows(M)+1)+1)
С уважением,
Михаил Каганский
NDTM Amarasekera 9/11/2016 3:38:00 PM
1 Pages (4 items)
