1 Pages (6 items)
Fourier transform - Mathcad Fourier transform doesn't work in SMath - Messages
#1 Posted: 5/14/2026 4:19:57 PM
Dear all,
I have a Mathcad Document about Fourier transform that I want to translate into SMath.
I already dowloaded the FFTPack plugin. I used the same functions from the Mathcad document which doesn't work in SMath.
I tried a bit but nothing is working. The error message says "The argument must be a scalar."
I attached screenshots from my SMath document and the original Mathcad document.
Does anyone have an idea or a helpful tip?
Thanks in advance
Thanks in advance
#2 Posted: 5/14/2026 4:26:36 PM
#4 Posted: 5/15/2026 7:07:59 AM
Thank you! That worked and the error message is gone.
I'm still having trouble plotting the graph. The graph is not being displayed but there isn't any error message.
Did I overlook something? Does the rfft() function work different in SMath than in Mathcad?
Thanks in advance
Thanks in advance
#5 Posted: 5/15/2026 7:57:42 AM
Check if it can help you. The graph has the correct shape but the values are different.fft_spalt_test(sergio).sm (10.62 KiB) downloaded 406 time(s).
Caro 5/15/2026 4:30:00 PM
1 Pages (6 items)
