1 Pages (15 items)
Vibrations of membranes - Messages
#1 Posted: 12/28/2017 5:10:57 PM
Vibrations of a circular membrane.The axisymmetric case
Solution are described with the help of Bessel functions .
https://en.wikipedia.org/wiki/Vibrations_of_a_circular_membrane
Bessel'2.sm (29.66 KiB) downloaded 1371 time(s).
#2 Posted: 12/31/2017 1:46:43 PM
Tanks Ber7: saved in your named file.
#3 Posted: 1/6/2018 5:14:01 AM
Vibrations of a rectangular membrane
Calculation formulas are taken from the book:S.Timoshenko,
Vibration Problems In Engineering
MemPl.sm (14.03 KiB) downloaded 1323 time(s).
3 users liked this post
#5 Posted: 1/19/2018 12:37:31 PM
Deflection of simply supported equilateral triangular plate
The plate rests on a frame in the form of an equilateral triangle.
The triangular part of the plate is loaded uniformly distributed
load. The equation of the surface of deflections of a triangular plate is taken
from the book of S.P.Timoshenko.Timoshenko S.P., Woinowsky-Krieger S. Theory of plates and shells. New York, NY: McGraw-Hill; 1959.
triangular plate.sm (12.86 KiB) downloaded 1293 time(s).
Andrey Ivashov 1/24/2018 4:37:00 PM, Davide Carpi 1/19/2018 8:26:00 PM, NDTM Amarasekera 1/19/2018 10:43:00 PM
#6 Posted: 1/19/2018 2:47:19 PM
Thanks Ber7 for that one and the other one few days ago.
#8 Posted: 1/25/2018 11:52:49 PM
WroteI tried to use the plugin Maxima
Thanks Ber7, I love those 3D, though it will never beat Mathcad 8... 11.
On my own, I published several times more than the entire Mathcad Community.
I don't miss them in Smath 6179, why ? purely useless for the Engineer.
They are just for the Gallery [Tom G. would say Peanut Gallery].
We are just waiting for a stable Smath version delivered with Maxima plugin
and more of the possible plugins. Scilab looks far superior to Maxima ?
#9 Posted: 1/29/2018 6:24:36 AM
Deflection of a Circular Plate.Plate contains rigid
inclusion of radius b and loaded at the Center
(Timoshenko,S.and Woinowsky-Krieger, S.,Theory of plates and shells, 1959)
Inclusion.sm (32.68 KiB) downloaded 1308 time(s).
Davide Carpi 1/29/2018 7:29:00 AM
#10 Posted: 1/26/2019 10:30:30 PM
Hello Beer7, is this vibration of a rectangular membrane equivalent to the deflection of a simply supported, uniformly loaded, rectangular plate? (leaving aside the physical parameters like plate thickness, Young's modulus etc.) I am only interested in the curvature on various locations on the surface, not in absolute values (max deflection can be calculated using simple civil engineering formulaes).
Thanks,
Laurent
Thanks,
Laurent
WroteVibrations of a rectangular membrane
#11 Posted: 1/27/2019 12:30:46 AM
WroteVibrations of a circular membrane.The axis symmetric case
Solutions are described with the help of Bessel functions .
Thanks Ber7, works great. Beautiful work.
mwbesselj(0,x) is ~ 4 times faster 15 decimals
Hart JZERO 5852 is 23 decimals up to ± 8.
Bessel JY.sm (75.19 KiB) downloaded 1260 time(s).
#12 Posted: 1/27/2019 1:55:42 AM
What happened, your previous post is gone with the wind ???
Try this, so much faster !
Bessel mwbesselj Membrane Ber7 [20190126].sm (31.26 KiB) downloaded 1173 time(s).
#13 Posted: 1/3/2021 5:47:58 AM
Vibrations of a triangular membrane
Calculation formulas are taken from thearticle:
http://ivdon.ru/uploads/article/pdf/IVD_44__1_Chernyshov.pdf_30f490557a.pdf
Vibration triangular membrane.sm (319.69 KiB) downloaded 1252 time(s).
Alvaro 1/4/2021 12:30:00 PM
#14 Posted: 1/3/2021 11:28:34 AM
Thanks, works fine after doctoring CreateMesh.
#15 Posted: 1/3/2021 1:23:53 PM
Vibrations of a triangular membrane(Maxima)
TriangularMembrane Maxima.sm (279.28 KiB) downloaded 1363 time(s).
1 Pages (15 items)
.png)
