1 Pages (8 items)
A simple animation - Messages
#1 Posted: 3/3/2012 7:07:23 AM
Hi
Like most people, I think, I've been very impressed by the animations uploaded by ber7. Unfortunately I've found them a bit difficult to understand (old age I think) so I've written and annotated a very simple one of my own:
https://smath.com/wiki/GetFile.aspx?File=forum_attach/bdrunagle/SimpleAnimation.zip
I hope it's correct, useful, and not too simple for this forum.
Brian
Brian
4 users liked this post
Radovan Omorjan 3/3/2012 8:22:00 AM, Andrey Ivashov 3/3/2012 8:43:00 AM, Fridel Selitsky 3/3/2012 8:47:00 AM, Davide Carpi 3/3/2012 9:22:00 AM
#2 Posted: 3/3/2012 12:26:06 PM
Very clean and good example. If I am not mistaken, there are only two tentative corrections for the code. Instead of
(0,0,".",10,"Blue",1,5)
(0,0,"O",10,"Blue",1,5)
you should use previously defined variables Ox and Oy
(Ox,Oy,".",10,"Blue",1,5)
(Ox,Oy,"O",10,"Blue",1,5)
#3 Posted: 3/4/2012 3:34:38 AM
Thanks very much for spotting that IVR. It's updated:
Brian
Brian
#4 Posted: 3/4/2012 5:45:34 AM
If Ox≠0, Oy≠0,
third and fourth line must be corrected:
Cx=Ox+OC*cos(δθ*t)
Cy=Oy+OC*sin(δθ*t)
Regards,Ber7
Cx=Ox+OC*cos(δθ*t)
Cy=Oy+OC*sin(δθ*t)
Regards,Ber7
#5 Posted: 3/4/2012 4:58:10 PM
Thanks ber7.
It also needs
Py:=Oy
Piston:=…Oy+Piston_radius
etc, etc
I want to tidy it up a bit more but I've run out of time for now. I'll check it over the coming week.
Brian
It also needs
Py:=Oy
etc, etc
Brian
#6 Posted: 3/11/2012 8:06:36 AM
Here is the updated animation.
https://smath.com/wiki/GetFile.aspx?File=forum_attach/bdrunagle/SimpleAnimation2.zip
Varying the values of Originx and Originy shift the animation as expected
I tried to tidy it up even more. In the above example, the origin is passed to the plot function using two parameters, Originx and Originy. I tried to pass the same values using a two-element vector, Origin, but without success: now I get a "t not defined" error in the 2D plot. To be consistent I also changed all the *x and *y parameters in the function to two-element vectors.
https://smath.com/wiki/GetFile.aspx?File=forum_attach/bdrunagle/SimpleAnimation2a.zip
Is there a special way to pass vectors to a function?
Is there a special way to define a vector inside a function?
Sorry, I'm still learning about SMath
By the way, I'm running SMath 0.93 on Windows 7
Brian
Brian
#7 Posted: 3/11/2012 12:38:46 PM
Slightly corrected your file,Regards.
https://smath.com/wiki/GetFile.aspx?File=SimpleAnimationM.rar
#8 Posted: 8/30/2012 1:11:14 AM
Square wheel
A square wheel rolls smoothly on inverted catenaries
References
G. B. Robison, Rockers and rollers, Math. Mag. 33 (1960), 139–144.
https://smath.com/wiki/GetFile.aspx?File=square_%20wheel.rar
References
3 users liked this post
kmihaylovich 8/30/2012 5:12:00 AM, Davide Carpi 8/30/2012 6:26:00 AM, Oscar Campo 8/30/2012 5:41:00 PM
1 Pages (8 items)
